3rd Brake Light Not Working
Old Aug 6, 2006 | 09:56 PM
tlgee's Avatar
tlgee is infamous around these parts
After installing a new wing and hood cover, my 3rd brake light stop working. I had to cut a few wires to remove the factory tail and hood. I probably should not of just hacked away. But I did.
Also dash light pops up when it wants the factory tail to go up. Ted at EVS says just to ignore it.
Anyone else have these problems after installing aftermarket wing????
Tommy
Old Aug 9, 2006 | 02:56 AM
syaero's Avatar
syaero is infamous around these parts
I had similar issue after installing an aftermarket wing (fixed) on my 996. I had to replace the factory wire harness with an OEM wire harness for fixed wing. This bypasses the brake light on the stock wing which is no longer there. The cost was $41 and it was a 5-10 min job. Give your local Porsche dealer a call, they should be able to help you.
Old Aug 9, 2006 | 01:33 PM
tlgee's Avatar
I just called the dealer and they have this part that was for my cabriolet, but it was only 33.00.
They called it add a third brake light for a a fixed tail.
Hopefully this is it.
Thanks!
cadman
Nov 13, 2025 08:57 AM
COBB Tuning
Jan 1, 2025 09:02 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Vrseis
Aug 20, 2015 07:41 AM
Walorus
Aug 18, 2015 01:39 PM
