add oil? how much?
Old Feb 8, 2004 | 05:41 AM
rabkay's Avatar
rabkay is infamous around these parts
add oil? how much?
so i warmed up my car - tried the oil level gizmo -it wen through its cycle and shows 2 bars low - now what? how much would you add?
thanks, larry
Old Feb 8, 2004 | 08:13 PM
WARDHOG's Avatar
WARDHOG is infamous around these parts
I wouldn't worry about it until it starts showing two bars from the bottom. You should also use the dipstick for more reliable readings. Also, consult your owners manual.
Old Feb 9, 2004 | 07:52 PM
Rodis's Avatar
Rodis is infamous around these parts
Take a quart, add a little and check the level again. Continue the process until you have the sufficient level. Keep your car running while adding and checking. Turbos dont have a dipstick so I have to check with the computer. But if you have both then check both at the end just to make sure. Turbos eat oil like crazy but non-turbos should not. I add a quart every 700 to 1000 miles depends on how hard I've been running the car. But do double check with the manual and a mechanic.
Ron
oo7
Sep 10, 2015 08:08 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
