Wheel Spacer Help ???!!!
Old Nov 14, 2006 | 10:43 PM
boochook's Avatar
boochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond repute
Fellow 6Speeders,
I have a set of 19" SSR GT3's that I purchased off a 993 Turbo. The rears fit just fine, but I am having issues with the fronts b/c they are 19x8 (not the 8.5" recommended). The wheels are rather close to the Red Calipers on my 996 C4S and have actually been rubbing on some spots. I was told I might be able to get spacers for the fronts but don't know what to get and where to start. Apparently I need to buy new bolts as well. Any suggestions/recommendations on where I can get a set and what's a guesstimate on the $$$$. Thanks.
Berk
Old Nov 15, 2006 | 01:29 PM
adybuncio's Avatar
Usually spacer kits come with bolts already, H&R makes them and so does others, Im sure others will chime in soon who have more experience on this.
Old Nov 15, 2006 | 04:57 PM
Redridge's Avatar
FVD has spacers, prices are OK the 7mm are popular size. https://shop.fvd.de/?VID=37854&VCD=8...t=3&display=20
Old Nov 15, 2006 | 08:06 PM
boochook's Avatar
Guys,
These are great sources. I truly appreciate the help you both have given to me. I'm assuming I need 15mm spacers to get the 1/2 inch or so clearance for an 8" to 8.5" or is my thought process completely off. I just want to get enough of a distance without going out too far. Your thoughts???
7mm or 15mm???
Old Nov 16, 2006 | 09:41 AM
Redridge's Avatar
15mm will clear the brakes, but will your tire clear the wheel well (fenders are somewhat rolled)? If its just touching the calipers then 7mm should do it as well.
Old Nov 16, 2006 | 02:11 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
What offset are the front SSR wheels? also have you lower your car?
Old Nov 16, 2006 | 04:09 PM
boochook's Avatar
The fronts are 19x8 and are touching the calipers, but I have not lowered the car. It's the stock set up. I guess I'm going with the 7mm. Thanks a lot guys. I truly appreciate it.
Berk
Old Nov 17, 2006 | 12:19 PM
Brucem's Avatar
Senior Member
Brucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to all
if you are barley touching go with 5mm or 7mm spacers. Talk to vivid racing or Sharkwerks and they should have the H&R spacers. They are hubcentric also.
btw: offset is different from the size..
Old Nov 17, 2006 | 07:14 PM
boochook's Avatar
Brucem,
Thanks my friend. I just ordered 7mm last night and am expecting them next week. Looking forward to putting the "shoes" back on.
Old Nov 17, 2006 | 07:20 PM
Brucem's Avatar
Senior Member
Originally Posted by boochook
Brucem,
not a problem... now where is my rep
Old Nov 17, 2006 | 07:39 PM
boochook's Avatar
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
