Need advice on how to make my car sound better..
Old Dec 23, 2006 | 12:30 PM
jpclinging's Avatar
jpclinging is infamous around these parts
My 99 has stock exhaust and it sounds pathetic except at high RPM and I want to change that. I don't need more power just much better sound from idle all the way through. If anyone can recommend a solution or has used mufflers I would be greatful.
Old Dec 23, 2006 | 12:32 PM
PorscheC4's Avatar
PorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant future
you have a PM.
Old Dec 23, 2006 | 12:36 PM
jpclinging's Avatar
Originally Posted by PorscheC4
you have a PM.
checked PM and nothing there?
Old Dec 23, 2006 | 12:41 PM
LUISGT3's Avatar
Get some muffler by-passes.
Old Dec 23, 2006 | 12:43 PM
jpclinging's Avatar
what are they and what do they do....what do they cost?
Old Dec 23, 2006 | 12:44 PM
LUISGT3's Avatar
Check the fabspeed banner on the sponsor links. There are some sound clips in there of the by-passes. They are around $500.
Old Dec 23, 2006 | 02:56 PM
JSG1901's Avatar
JSG1901 is infamous around these parts
A simple solution that will give you a bit more sound: Open the air cleaner and remove the muffler which sticks out the small (2" or so) hole in the top.
You'll need to find something to fill this hole. I found some PVC pipe which was designed to connect two sizes of pipe (2" to 2-1/4" maybe...don't have it here to measure). I put the wider end inside the air cleaner with the smaller end protruding through the hole. With a little duct tape I thickened the outer diameter of the PVC until it was a press-fit in the air cleaner hole. Close off the top of this pipe and then re-connect the hose which originally went into the muffler so no unfiltered air gets into the engine.
This is a $2 fix which gives you substantially the same thing as Fabspeed's $225 intake tweak. It adds more sound, particuarly in the upper rev ranges.
Old Dec 24, 2006 | 12:04 PM
AG996LV's Avatar
AG996LV is infamous around these parts
Fabspeed exhaust. Will give you deeper, more powerful sound and save a few pounds. I might even have a set available soon.... if I trade in my car I will take off the exhaust and put the stock ones back on. PM me if your interested.
Old Dec 24, 2006 | 03:33 PM
SRC4S's Avatar
SRC4S is infamous around these parts
Porsche Sport Exhaust. I love the way it sounds.
Old Dec 24, 2006 | 04:34 PM
ZEMDOGG's Avatar
ZEMDOGG is infamous around these parts
Take those mufflers off! Fabspeed bypass pipes!
Old Dec 24, 2006 | 05:25 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
There are a number of exhausts you can buy and they all sound different. Try to find someone in your area that has an aftermarket exhaust you can listen to before you buy. Exhaust sound is very subjective.
Old Dec 24, 2006 | 06:11 PM
jpclinging's Avatar
PM sent on Fabspeed
Old Dec 24, 2006 | 09:36 PM
AG996LV's Avatar
PM replied.
Old Dec 26, 2006 | 07:04 PM
Exlondoner's Avatar
Exlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud of
TechArt Exhaust here, everyone turns around!
Old Dec 27, 2006 | 03:23 PM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
fabspeed mufflers with tips.
