stuck in gear?
Old Jan 15, 2007 | 11:10 PM
vujade's Avatar
vujade is infamous around these parts
stuck in gear?
Just got home from eating some Sushi. On the way home I took off at the
light, went to shift into second gear and there was nothing there. I thought
I was in neutral (thought I missed a shift), so I put it into 3rd gear, went to
go to fourth and realized I was stuck in 3rd.
Im stuck in 3rd gear. I can move the shifter forwards and backwards like
I am going from 3rd to 4th. But it stays in 3rd. I cannot move it right or
left to get into any other gear.
Any one ever have this happen?
What could this be?
thanks
Joe
Old Jan 15, 2007 | 11:19 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
The shifter uses 2 cables, which are attached with plastic connectors. The one for for/aft movement, like 3rd to 4th may have broken, they wear pretty fast. Or another cable attachment may have come loose, or a cable may have snapped. You might try to go on B&M's web site and download the instructions for installing their in car short shift kit. This will show you how to remove the rear center console so you can see the shift mechanism. You will probably be able to see what is wrong here (unless it is a connection under the car.). When I installed the short shifter in my car the plastic linkage was pretty worn and sloppy. I replaced it with an Agency Power aluminum linkage. If tyou have the console out, now is the time to install a short shift kit, you will love it.
Let me know if this helps.
Old Jan 17, 2007 | 02:14 AM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Yes, don't strong arm nothing until you get to pull up that center console.....
-Eli
Old Jan 17, 2007 | 04:07 AM
Redridge's Avatar
and pray that the prob is under the console and not under the car.
Old Jan 17, 2007 | 08:03 PM
vujade's Avatar
turns out, it was one of the cables...
thanks for all your help
Old Jan 18, 2007 | 12:24 PM
Glad to hear the bit of good news....
Drive-on vujade, drive-on......
-Eli
Old Jan 18, 2007 | 02:01 PM
vujade's Avatar
-Eli
Definitely good news... whats even better news is that I got it done
for half the price that the dealer wanted!!!
SlinginHoss
11
Oct 8, 2025 05:16 PM
Steve Jarvis
Apr 1, 2023 06:49 PM
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
