Wheel fitment for a narrow body 996
Old Jan 19, 2007 | 11:41 AM
wittenbergj's Avatar
wittenbergj is infamous around these parts
Does anyone know if these will fit on a narrow body 996
Front: 19 X 8 with 57mm offset
Rear: 19x11 with 67mm offset
Thanks,
Old Jan 19, 2007 | 03:02 PM
Redridge's Avatar
with those offset yes. similar to these http://cgi.ebay.com/ebaymotors/Porsc...QQcmdZViewItem, i believe newport996 are running these.
Old Jan 19, 2007 | 03:40 PM
stanm5's Avatar
stanm5 is infamous around these parts
I'm running those sizes and offsets (same as Newport) and they fit perfectly.
Cheers,
Stan
Old Jan 19, 2007 | 03:58 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
yes...perfect fit...add a 15mm spacer to the fronts to push them out a bit....
Old Jan 19, 2007 | 04:18 PM
Thanks, now to haggle on the price
Old Jan 22, 2007 | 01:45 PM
SilverBlue's Avatar
SilverBlue is infamous around these parts
Is this another good answer? Exact sizes you're asking about. Car is lowered with PSS9's and still no clearance issues.
Old Jan 28, 2007 | 06:26 PM
my996's Avatar
1999 C4 Cab 6 Speed
my996 is infamous around these parts
Hi Newport, What size tires are you running on your 8's and 11's? Thanks
Old Jan 28, 2007 | 07:14 PM
sms's Avatar
sms
sms is infamous around these parts
I have those exact sizes and offsets (997 "S" wheels) with 245/35s and 315/25s with H&R lowering springs (1.25") and absolutely no rubbing although I avoid lock to lock (also due to the cup car brake ducts). Thanks for the tip on the 15mm spacers as I have read this helps to start (along with an aggressive alignment) fighting the factory understeer. Of course there is a LOT more one can do for that.
Old Jan 28, 2007 | 07:33 PM
my996's Avatar
1999 C4 Cab 6 Speed
Thanks for the reply SMS, however, you have an 02 and I have a 99. I am told that there are slight differences that might be a problem for me. I just thought that since Newport has a 99, I'd see what he is running.
On another note, SMS, how is cornering in your car compared to before you switched?
Old Jan 28, 2007 | 07:41 PM
sms's Avatar
sms
I am no expert, but for body, offset, brakes, etc. there should be no difference. Anyway, I am yet to get the car on the track as here in the east it is not like my SoCal roots.....tracks re-open in March. I had the car track aligned when I installed the wheels and the turn-in is TOTALLY superior.... i.e. when you turn it turns! This would be primarily due to the alignment settings (toe-in, camber). As for road driving, what can I say, it was on rails before and it still is but now with a bit more contact patch in the rear (285 to 315). Unfortunately this increases understeer which is why I am interested in putting spacers on the front as suggested. Good luck!
Old Jan 28, 2007 | 08:03 PM
newport996's Avatar
I have 235/35/19 and 285/30/19....SMS...you going with 315/25 in the rear may be a negative in performance...you mention the added understeer and the smaller, stiffer sidewall is a disadvantage for performance as well.....
Old Jan 28, 2007 | 09:07 PM
sms's Avatar
sms
I wanted to go with 30s in the rear but could not find that size in a reasonably priced tire. This set of 19s is for try out before getting a track set or going with my factory 18s. I evaluated quite a few opinions and a lot of variables before going forward with the tire size issue. The thought process, albeit possibly flawed, was more grip in the rear and I can always tune out the understeer until I find a happy medium that gets the rear around when I need it to on track.
PS: I keep staring at your car.....truly tasteful mods.
Old Jan 28, 2007 | 09:57 PM
my996's Avatar
1999 C4 Cab 6 Speed
Newport, when you replaced your front bumper, did you also replace the rubber air intakes behind the bumper? - If not, do you notice any increase in temp compared to before the mod?
Old Jan 28, 2007 | 09:58 PM
newport996's Avatar
no increased temps..not sure if they were replaced...the shop that did the conversion didnt mention it...but that doesnt mean it wasnt done....
Old Jan 28, 2007 | 10:03 PM
my996's Avatar
1999 C4 Cab 6 Speed
When ever you get a chance, could you take a look through the grill to see. You should be able to make out if the rubber fits snug or if the old one is left in place in which case, it will hang down from the top (on the inside).
