Stainless Steel Door Sill---Installation HELP!
Old Mar 13, 2007 | 08:35 PM
MAD CAT's Avatar
MAD CAT is infamous around these parts
Hi all,
Got a pair of the Carrera stainless steel door sill and tried to install it yesterday, somehow the original black plastic one is so hard to take it off, has anyone done this yet? I tried the hair dryer/dental floss method, not working... anyone with any advise?
TIA
Old Mar 13, 2007 | 08:48 PM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
I replaced my original black sills.
Get a good grip on the rear edge and pull.
It will come up.
Then use goof off to remove the old glue.
Old Mar 14, 2007 | 04:31 PM
DeAd-EyE's Avatar
DeAd-EyE is infamous around these parts
get under it with fishing line/metal string and go from one end to another "cutting" it out
Old Mar 14, 2007 | 06:39 PM
MAD CAT's Avatar
Thanks for your tips...
Do I just pull it hard like there's no tomorrow? This thing is like suuuppppeeeer-glued and doesn't want to leave the car !!!
And I did tried the floss/fish line, but before I can cut in-between the sill and the car, it cut the line first...
I will try again...
Old Mar 14, 2007 | 07:28 PM
Redridge's Avatar
gotta use the heat gun... and be patient!!!!
Old Mar 14, 2007 | 07:40 PM
I wedged a plastic putty knife under the edge and got a good grip, then just pulled.
My car was new then.
Maybe that makes a difference with the glue.
What year is yours?
Old Mar 14, 2007 | 08:25 PM
MAD CAT's Avatar
Mine is an 02... maybe the glue got fixed down for 5+ years...
Old Mar 14, 2007 | 09:21 PM
That's what I'm thinking.
Old Mar 14, 2007 | 09:24 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
I heated mine up and had to put a HUGE amount of pressure on it. Then comes the fun of cleaning up the old glue with the 3M adhesive remover...
Sep 3, 2015 04:56 PM
