Will the stock 02 996 eyebrows and airducts work with the TT front bumper conversion?
Old Apr 12, 2004 | 12:16 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
I've gotten a lot of different answers on this and I appreciate everyone's help so far.
Does anyone know for sure if you can you use the stock eye brows and air ducts from the standard 02 996 front bumper with the 02 TT bumper?
Any idea where I can get the bottom turbo lip and grills cheap? I found a bumper for a very reasonable price but does not come with the lip and grills, which are quite expensive from the dealer.
Old Apr 12, 2004 | 12:18 PM
Marx's Avatar
Marx is infamous around these parts
Re: Will the stock 02 996 eyebrows and airducts work with the TT front bumper conversion?
The air ducts need to be modified a little. You need to enlarge the front opening a little... but that's pretty much it.
I am not sure what you call "eye brows".
Old Apr 12, 2004 | 01:39 PM
CA996's Avatar
CA996 is infamous around these parts
Call Dayton at (818)388-7197 I just purchased the left and right grills for $85 each and the turbo lip is about $225. Don't know how much the center grill is. The left and right grills retail for around $185 each.
Old Apr 12, 2004 | 01:44 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
Re: Re: Will the stock 02 996 eyebrows and airducts work with the TT front bumper conversion?
i dunno about the air ducts needing to be enlarge.. by design did no such thing... when they isntalled the tt bumper on my car..
Old Apr 12, 2004 | 01:49 PM
Marx:
i don't know why them call them eyebrows either since they're on the bottom of the headlights. i'm referring to the trim pieces that are on the bottom of the headlights between the bumper and the headlights. the dealer says they're a different part number but i can't imagine that they'd be different. someone else posted that they reused their stock ones.
the "front opening" that you posted about. are you referring to the air ducts? what specifically has to be done?
Old Apr 12, 2004 | 02:18 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
I think that Carnewal.com has the lip that you need. Is is listed as the C4 "Wide Body" chin spoiler. At the current conversion rate, its about $120.
Old Apr 12, 2004 | 02:21 PM
CA996's Avatar
The C4S lip is alot cheaper than the turbo lip.
Old Apr 12, 2004 | 02:43 PM
Marx's Avatar
Re: Re: Re: Will the stock 02 996 eyebrows and airducts work with the TT front bumper conversion?
It will fit without modifying the air duct opening, but it will look a little strange. Can you post a close-up of the right or left grill of your TT-front bumper? It simply doesn't look "right".
Also, for the center grille, you should use the C4S center grille and not the TT center grille. The middle C4S grille in the front bumper comes with a drilled metal plate behind the plastic grille, which looks a little better than just the grille with no additional radiator installed behind it (like it is on the TT). Check a few close-up pics of the center grille on a C4S and on a TT front bumper to see what I'm talking about.
Not sure about the eyebrows though. My guess would be that they fit.
Old Apr 12, 2004 | 03:30 PM
HI MARX
SURE I WILL POST A PIC.. but iw ont be able until next week my brother has my 996 and i have his ... we traded cars last week hopefully ill get my baby back next week
Old Apr 12, 2004 | 03:38 PM
opps actually i do have a picture of my front bumper..
here'sa pic of it, it was retouched by britt - the photo shoppin maniac grey ghost..
Old Apr 12, 2004 | 04:09 PM
Marx's Avatar
Hey Joe, thanks for posting the pic. A bit more of a closeup would be good though.
The casing of the air-vents should look a little different from what you see when you look into the TT bumper. You can enlarge the front-openings of the air-vents simply by cutting away the edges of the opening a little more so that the opening will be bigger than the opening in the front bumper.
Damn... this is really hard to explain without actually showing and pointing at the panels I talk about. It's not really a required mod, but it would complete the look of your turbo front.
Also, what did you do on the center-grille? Did you use the C4S grille with the drilled panel? I hardly can see the details of your center grille on your pic.
Old Apr 12, 2004 | 04:13 PM
thanks for the compliemnts marx, as for the bumper and grille vrything came froma TT i bought it used and it came with everything form girl to eyebrows etc.. i will try to look for pics at my hoe of the front if i do i will post it..
Old Apr 12, 2004 | 04:27 PM
Marx's Avatar
I would replace the center grille with the one from a C4S. As I said before, the grille from the C4S comes with a drilled plate (in black) behind the grille and thus you cannot look through the center-grille.
This makes sense, since the C4S (like the normal C2) doesn't have a third radiator installed behind the center grille. Thus it simply looks a little smoother to install the C4S center grille on 996 Carreras that don't have a third/center radiator.
Old Apr 12, 2004 | 05:48 PM
So what's up with the eyebrow's? Do they need to be replaced or can You reuse the stock ones. Has anyone compared the two parts (turbo vs non turbo to see if they're different?
Old Apr 12, 2004 | 06:21 PM
CA996's Avatar
As far as the looks I plan on installing a black mesh BEHIND the factory grills so that you cannot see behind the grills. The mesh cost $35.00 and can be attached to the car itself before the bumper gets put on.
