My Battery Blew Up!
Old Aug 14, 2009 | 02:56 PM
  #31
Mother's Avatar
Mother is infamous around these parts
Originally Posted by BavarianAudi
I wanted to purchase the optima battery but thought that it would keep dying out if i kept the car in accessory mode. I ended up getting a giant Bosch one. I just wanna know from your experiences how long can you keep it in accessory mode on an optima battery?
I have the yellow top optima and I have been building my car for 3 years and drive very little and just keep charge on it every once in a while when I run it down from playing the radio, It still works great and in 110 degree summers.
Old Aug 14, 2009 | 03:01 PM
  #32
Mother's Avatar
Originally Posted by Brando
The plastic battery cover did a good job of containment.
I cleaned everything really well and then took a pitcher and mixed in baking soda and poured it over and into everything, cleaned it again and sprayed WD40 onto all metal and wiped it down.
You had me worried for a minute. when mine blew I got acid on me as well so I had to qwickly take a jump in the pool....AAAHHHH!!!
Old Aug 14, 2009 | 06:14 PM
  #33
delirium's Avatar
delirium is infamous around these parts
could this happen to the sealed batteries too? I just bought a kirkland sealed battery, I dont think i can fill up the water on it.
Old Aug 18, 2009 | 03:02 PM
  #34
perryinva's Avatar
perryinva is infamous around these parts
It can happen to ANY lead acid battery, sealed or not. The sealed ones have a designed relief port. This should never happen to the normal batteries in a 996 unless the vent tube is clogged or pinched, which is probably the reason his Interstate blew up. The vent is there to vent the hyddogen pressure that can build up. Don't assume it was a defective battery, just because the new one works fine. The old one was fine right until it blew up. Take some compressed air and blow out the vent tube and verify it is clear. Check water every few months.
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
