Coolant Leak
Old Aug 6, 2007 | 07:40 AM
carcrazee's Avatar
carcrazee is infamous around these parts
Coolant Leak
after a nice drive, the coolant leaks under the left rear tire. I 've notice this several times after driving the car hard. the leak stop once the car cools down. While driving, engine temp is normal. is this something i should be concern about or could the dealer have added too much coolant from my last service? t.i.a. for your feed back.
Old Aug 6, 2007 | 07:43 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
Probably leaking coolant tank. DIY.
Check Sunset for pricing.
Old Aug 6, 2007 | 07:55 AM
carcrazee's Avatar
zdr2k. thanks for the feed back. I'll check the tank for leaks when i get home. but, it only leaks (drip) when the engine is hot and once the car cools down, it stops.
Old Aug 6, 2007 | 08:01 AM
spyderman33's Avatar
spyderman33 is infamous around these parts
I would look around after driving for the actual leak... It can also be a bad coolant tank cap... look around and identify the source before you start taking stuff apart...
Old Aug 6, 2007 | 08:51 AM
zdr2k's Avatar
That was exactly my indication. The tank was leaking from the bottom and it is difficult or nearly impossible to detect.
check this DIY.
http://www.renntech.org/forums/index.php?showtopic=8024
Must register to view (free)
jorge
Old Aug 6, 2007 | 08:54 AM
Redridge's Avatar
+1, this is typical
Old Aug 6, 2007 | 11:35 AM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Change the tank cap first, then observe and see if leak goes away. You should change out the cap about every two years because they beak down. Cap cost around $25 or so.
Old Aug 6, 2007 | 01:11 PM
eight0zero's Avatar
eight0zero is infamous around these parts
Yep had the same problem. From what I hear it's very common since the coolant tanks are made of plastic, which makes it prone to breaks.
The tank was replaced and now, all better...
Old Aug 6, 2007 | 02:53 PM
AsianImage's Avatar
AsianImage is a jewel in the roughAsianImage is a jewel in the roughAsianImage is a jewel in the rough
def coolant tank....I had the same problem
Old Aug 6, 2007 | 03:25 PM
Eric523's Avatar
Eric523 is infamous around these parts
Its under pressure at temp.
Old Aug 7, 2007 | 06:21 AM
carcrazee's Avatar
thanks for all the feed back. taking the car in next week to have the tank inspect/replace.
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
