Rear Sitting Lower Than Normal?
Old Aug 23, 2007 | 11:52 AM
Russcan's Avatar
Russcan is infamous around these parts
[QUOTE]
Its possible that the installer didnt remove the rubber spacers in the front, they are good for a least 1/4" in height. This is how my car came out originally too. When the car was in for the alignment, I had the spacers removed and came out perfect Good luck!
Where are these rubber spacers you are reffering to? At the top of the spring or the bottom? Also, There were 2 square rubber blocks that had a notch out of them were a spring coil might go, they came with the springs and my guy said he did not use them. He thought they were intended to stop the springs from grinding. Were these intended to go into the rear springs to stop them sagging?
Old Aug 23, 2007 | 09:22 PM
Russcan's Avatar
Does anyone know where these rubber spacers are in the front the guy mentioned? Does this sound possible? If so please explain where they are and how to get to them!
Old Aug 24, 2007 | 09:22 AM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
The spacers on my car (don't know if yours is the same) were in between the top of the spring and spring cup which holds the top of the spring (perch). The black round spacer just pulls off of the bottom away from the metal, looks like a smashed donut or large rubber washer. Hope this helps...
Old Aug 24, 2007 | 12:38 PM
Russcan's Avatar
Hey man thank you for you help. My installer did say he saw those, but because they were there when the Oem springs were there that he left them. I do not mind taking them out to get the front to rear rake correct, but i want to be sure this is normal and is suppose to be done with the spring install. I was wondering if you have any metal grinding or rattling noise as a result in removing them. Many Thank's
Russ
Old Aug 24, 2007 | 02:29 PM
RocC4S's Avatar
There is no noise to speak of. My springs actually have a plastic/rubber sleeve around the metal which prevents noise.
The shop that did the alignment actually suggested it to correct the same problem you are having.
Glad to help bro and good luck!
Old Aug 24, 2007 | 03:15 PM
Russcan's Avatar
I will take'em out soon. I'll keep you posted to the results. I hope it works to solve the issue. I will be very happy if I can get some front rake.
Russ
Old Sep 10, 2007 | 07:37 PM
Russcan's Avatar
Does anyone else know if it's ok to remove these rubber spacers from the front spring perch? I was having the alignment done today and told the guy about this issue. He said he would not remove them. Please let me know to leave them or remove them.
Thanks, RUSS
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
Aug 19, 2015 06:35 PM
