Bullet proof track car
Old Sep 3, 2007 | 11:24 AM
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
To all you track junkies:
Has anyone put one of these oil pans in?
http://e-partssales.com/Merchant2/me..._Code=996sport
I went on a spirited drive on the back roads and during a hard corner a "yellow" light come on in the dash and then went off. I only saw it from the corner of my eye so I did not see exactly what it was. Could it have been because of the oil sloshing around?
Old Sep 3, 2007 | 11:35 AM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
the PSM light?
Old Sep 3, 2007 | 11:52 AM
c2mojo's Avatar
c2mojo is infamous around these parts
Funny that you posted this. I just ordered it and the 3rd radiator in preparation for my car's extensive track schedule next year. I talked to a the owner of Midwest Eurosports and he told me that a lot of std p-cars come in overheated and/or starved of oil when you track it extensively. He tried to tell me to sell the car and buy a GT3 because of the dry-sump setup but I said that was not in the picture right now and he said I can band-aid it buy getting the baffle and radiator.
So I got them on order and will tell you all how it goes. I also ordered the Gt3 RS brake ducts to help cooling.
Old Sep 3, 2007 | 01:50 PM
easyc's Avatar
easyc is infamous around these parts
I haven't yet, but many have... here is an alternative... http://www.bkauto.com/porsche/r9095.php
And that light could have just been PSM. 997 GT3 brake ducts will fit and are a TON cheaper... the 997 GT3 Cup ducts are cheaper as well, but must be ordered through Motorsports
Old Sep 3, 2007 | 02:06 PM
ChromeHearts's Avatar
ChromeHearts is infamous around these parts
Do you know which Motorsport shop sells the 997GT3Cup ducts?
Old Sep 4, 2007 | 09:00 AM
StuartFirm's Avatar
StuartFirm is infamous around these parts
My vote is that it was Traction Control if it was during a spirited drive, rather than an oil light. I have tracked my 1999 EVOMS SC'd 996 C2 many times and never had any issue with oil starvation. Although, if you tuck up under another car for a lap or two, it will start to overheat like a MF. My car (with the 3rd radiator, obviously), certainly likes to have clean air flowing over the front AT ALL TIMES. Just a half a lap up under the back end of another car will result in a significant increase in the water temperature. At two laps of hard running behind another car, results in overheating. The trick for me is to get in behind the car, set up your pass, then pass; otherwise, you have to back off cool down and try it all over again.
G/L with your upgrades.
Old Sep 5, 2007 | 12:51 AM
auto-xr's Avatar
auto-xr is infamous around these parts
Could be the traction control light. I've seen it come up on my car a few times =)
Old Sep 5, 2007 | 09:59 AM
Thanks for the insite. I think you all are correct it was probably the traction control light coming on.
I have the rear cage in place, does anyone know where I can get the "black" version of these belts?
http://e-partssales.com/Merchant2/me...ry_Code=996exc
3rd radiator is going in this month at Sharkwerks.
The car is a C2 with basic mods, intake, plenum, headers, exshaust, flashed computer, and LWFW.
The suspension is Motons, w/H&R sways. 315 in the rear and 235s up front. Should I go to 245s up front? Also what brand tires do you like for track/street use? Do Toyo T1s work well on this car?
Thanks for all the input gang.
Cheers.
Old Sep 5, 2007 | 11:25 AM
Redridge's Avatar
Cheers.
Isnt this the evo sc car? 3rd radiator is on the the car no? or they unbolted the sc?... sorry if this has been covered before on other threads... as far as the x51 pan is concerned, It a great peace of mind. The brake ducts... my brakes performed great at the track, so it must of worked...
Old Sep 7, 2007 | 10:29 PM
What fluids do you use? Motor oil, trans oil, water-wetter, brake fluid, etc.?
PorscheEnthusiast
Nov 13, 2015 02:23 PM
mjacobellis
Aug 20, 2015 09:13 AM
pwdrhound
Aug 20, 2015 05:54 AM
Gewgaw
Aug 19, 2015 11:52 PM
