Lightness at the front at high speed?
Old Feb 12, 2008 | 09:59 PM
TT Surgeon's Avatar
150 mph at WG lap after lap, rock stable, check your tire pressure(hot) and alignment. Maybe you're not used to 500hp?? ... yet
Old Feb 12, 2008 | 11:05 PM
PrestonG's Avatar
PrestonG is infamous around these parts
hah mines not stock
Old Feb 13, 2008 | 08:44 AM
PIXC55's Avatar
PIXC55 is infamous around these parts
100mph onLY !!!!!! come on
Old Feb 13, 2008 | 08:54 AM
Hernando's Avatar
Hernando is infamous around these parts
You should check the Alignment, and tire pressure. I have had the 997TT up to 187, and it felt pretty stable all the way there. however at those high speeds it will begin to get a little light. However at 100 you should be fine. If you feel like you need added suction or downforce, I recommend that you get front and rear diffusers (I like the ones from WERKS).
Old Feb 13, 2008 | 09:12 AM
Porsche997TT's Avatar
Porsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to behold
the only time I felt my front end get floaty was when I hammered it on a bridge that was on the bumpy side(114mph)
Old Feb 14, 2008 | 04:04 AM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
Must be an alignment/tire pressure issue. It took 3 alignments before I was satisfied with my car. Had all sorts of "floaty" issues at speed around sweepers etc. I still do but nowhere near as bad (car is still stock). Now on the straights it was rock solid at 150mph. 100mph is barely crusing speed on this car. Have it looked at. When my car was not aligned properly I also felt crosswinds affecting the car more. Now its much better. Alignment is critical in these high performance AWD cars (along with proper tire pressures).
Old Feb 14, 2008 | 08:03 AM
PrestonG's Avatar
Ya a race alignment I am sure would help alot, however I have a racecar for that. Being on a track was more a one time thing for my 997
Old Feb 14, 2008 | 08:28 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I am routinely at 150-165mph on the straights of my local track, and with the correct toe front and rear the car feels like I am doing 40mph. There are no steering issues. Another thing to check is your wheel balance as well. Make sure they get done on a higher end machine.
Old Feb 14, 2008 | 10:09 AM
bbywu's Avatar
you need a better spoiler...
Old Feb 14, 2008 | 10:30 AM
PrestonG's Avatar
That would make it worse
Old Feb 25, 2008 | 06:52 AM
Mishal's Avatar
Mishal is infamous around these parts
I'm in Dubai, and even on the 8 lane expressway (where crosswinds are severe) I have no problems - even at 120 mph the car feels beyond solid and planted
Old Feb 25, 2008 | 08:02 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
That is just too funny
Old Feb 25, 2008 | 08:49 PM
iLLM3's Avatar
Originally Posted by eclou
Hit any curbs or potholes recently? You could experience much of those symptoms if your front toe alignment was knocked out of spec. Get the alignment checked out
Right on the money, alignment issue, almost 99% it is!
Old Feb 26, 2008 | 04:50 AM
TurboTronic's Avatar
TurboTronic is infamous around these parts
The problem is resolved. We had strong gusty winds in Qatar for a little over a week. Now that the winds have died down, the car is solid as a rock. I am still somewhat surprised as to how much the car's stability is affected by around 40mph sidewinds.
Old Feb 26, 2008 | 08:21 AM
eclou's Avatar
I am surprised you are testing high speed stability in light of 40 mph crosswinds. That's not something I would be keen on doing.
