Help Pls: What Do You Use for Exter. Spot Cleaner?
Old Feb 26, 2008 | 12:36 PM
Barrister's Avatar
Barrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to behold
Originally Posted by cannga
Barrister,
Wow, thanks for taking the time to post all the URL's. I have Meguiars Scratch X and didn't think to use it because it is a polisher & scratch remover and as such I thought I shouldn't use it that often since it works by thinning the top layer? Your thoughts? TIA.
Scratch X is not nearly abrasive enough to erode the clear coat. You can use it regularly.
You should look in the detailing section of the forum. There is a guy that frequents it named Moe Mistry. His is a pro detailer here in OC. He has a lot of knowledge and seems like a straight shooter.
Old Mar 2, 2008 | 12:12 AM
MoeMistry's Avatar
Premium Sponsor
Every few days my fairly light color car (red) would accumulate these multiple little black dots, about 1 mm or so in diameter, around the exhaust area and behind front wheels. I would assume it's either oil or tar. I use P21S Total Auto Wash which works great but does require a lot of back and forth scrubbing. I also used Turtle Wax Bug & Tar Remover but that doesn't work nearly as well. Any recommendation please? Thanks in advance.
If this is a routine problem, then it just may be the route you take. Are there new construction, new paved roads, etc. To safely remove these spots, which I assume is probably tar or asphalt, you can simply clay. Then you would polish and wax. A good polish, if you didn't want to clay, that would safely and gently remove the tar spots is Zymol HD-Cleanse. You would then follow it with a wax. Hope this helps. You may also want to post some pictures here. But it sounds like it's coming from the route you drive and this would be the simplest remedy.
Old Mar 2, 2008 | 01:08 AM
cannga's Avatar
Ah, you are THE MoeMistry I've been hearing about! Thanks for sharing your knowledge; per Barrister's (or someone) suggestion, I actually have been reading some of your (excellent) posts in the detail forum.
I suspect, besides tar as you mentioned, these dots could possibly also be exhaust soot or residual oil picked up from street. They are about 1-3mm in diameter, seen in the back of the car around exhaust area and lower parts of car behind front wheels. (I suspect I am not the only light color Turbo owners who observe this, so your answers ARE being watched. ) Whatever they are, here is what I've done and would really appreciate your inputs.
1. P21S Auto Wash: Not good. I have to scrub back and forth many times.
2. 3M Adhesive Remover (Contents: vm&p naphtha, xylene, ethylbenzene and propane): Works like magic. The black spot come off easily and immediately.
3. Mineral Spirits: I was about to try this next. Expect same result as 2 since I've seen both of these in the paint section of Home Depot.
4. Meguiars Scratch X: Also works, the most powerful but requires a little more scrubbing than the 3M Adhesive Remover.
Given what I've found and how often these dots appear, I was thinking the easiest solution would seem to be either 2 or 3 above, and then 4 for the tough ones.
1. Your thoughts?
2. No harm done in the long run with mineral spirits or 3M Adhesive Remover?? Should I be concerned about all the scary sounding hydrocarbon ring compounds in the 3M Adhesive Remover?
3. Does Zymol HD-Cleanse work on the same principle as Meguiars Scratch X? Do you prefer one over the other?
Old Mar 2, 2008 | 01:35 AM
atomic80's Avatar
+1 on the Zymol HD-Cleanse. One of the best products I've ever used! You're on the right track here, Can.
Glasgo
Nov 30, 2015 02:37 PM
