Does 315/25 on 20 inch tyre exists ???
Old May 12, 2008 | 05:52 AM
GT RUS's Avatar
GT RUS is just really niceGT RUS is just really niceGT RUS is just really niceGT RUS is just really niceGT RUS is just really nice
The car that I am buying has Champion 20x11 wheel with 305/25 at the back...I think that profile is too small and narrow for such big wheels... and for our roads...
I know most of the tuners here put 325/25 at the rear on 20i wheels... but on wider rims...this way you get higher porfile and better grip and hook up...and that waht I want as well...
Anyone knows if such tyres exists, I've search tireracks and didnt find anythings...I think it can fit on 11 wide wheel...or not ???
Old May 12, 2008 | 08:53 AM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
315/25/20 - Toyo T1R's. Tirerack doesn't sell Toyo's.
You can try discount tire.
Old May 12, 2008 | 08:54 AM
roncfpz's Avatar
roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !
Toyo makes a 315/25/20 - the T1R I believe. I also think you would be fine with 325 on an 11 inch wheel.
Old May 12, 2008 | 08:57 AM
ALPINE_997's Avatar
Champion puts on 325/25/20 on their wheels 11 inch. unless they don't have them in stock. The 325/25/20's are not exactly easy to get especially in PS2's.
Old May 12, 2008 | 11:13 AM
GT RUS's Avatar
Thanks guys...are you shure about that ???
My car has Contis Sport Contact 3 245/30 front and 305/25 rears
So I should go an get rear set of TOYOs or 305/25 rear is fine ???
I dont know should I do...keep as it is and when they wear out put 325 or stay with 305...less weight better perfomance in straightline
Old May 12, 2008 | 12:13 PM
ALPINE_997's Avatar
RUS you seem to be focused only on straight line which is okay but the quality of this car is more than for just a 1/4 drag race.
I would keep the tires to wear them out. The 305's are better for the 11"s rims than 325's in my opinion. You won't get much more grip out of them going with a 325/25/20.
Old May 12, 2008 | 12:17 PM
HotRodGuy's Avatar
www.edgeracing.com is good for Toyo's
Old May 12, 2008 | 03:17 PM
jonasgranlund's Avatar
jonasgranlund is infamous around these parts
325 on 11 inch is alot, original 996TT have 295 on 11.5 inch.
305 on 11 is ok but above that is to stretch the limit in my opinion.
Old May 12, 2008 | 03:30 PM
roncfpz's Avatar
Keep in mind not all tire manufacturers are the same. Some 325s are larger than others. Here is a Pirelli 325 on Techart 11"............no issues.
Old May 12, 2008 | 04:04 PM
dmoney's Avatar
dmoney is infamous around these parts
def. 305 on 11 inch & 325 on 11.5 or more... **** I wish I could get 345 25 20's on my 20 x 12
go with the pzero way better than ps2 imo... G.L.
Old May 17, 2008 | 10:26 AM
GT RUS's Avatar
Thanks but I am worrying more about how thin those side wall on 305/25...I dont want to destrpy those wheels the ast time I go out with a car...roads are not that good over here...so I am definatley gong to switch to 315/25 or 325...
Old May 17, 2008 | 10:29 AM
GT RUS's Avatar
Can any wheels expert chime inn...there seems to be confusion...some people inlcuding ME dont think that 11s would accomadate 325s and some say they will...what is the best solution for 11s...I will definately change the rear tyres...I think I can go 325/25 Contis but I thinkg they would be too wide for 11s or go for 315 Toyo which should fit...
Old May 17, 2008 | 12:30 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
Im sure you can squeeze the 325 on there, but the 305 or 315 is a better option. For example, the Pirelli 325/25/20 is designed for a 12" wheel, but you arent supposed to go narrower than a 11.5" wheel.
Old May 17, 2008 | 03:08 PM
GT RUS's Avatar
Thanks...then I will go for 315...I think its the best...and radius is the same as stock...
Old May 18, 2008 | 09:07 AM
jhbrennan's Avatar
Michelin PS2 specs for 325/25-20 recommend rim width 11.5 to 12.5
