to pccb or not to...
Old May 18, 2008 | 08:59 PM
  #31
acf's Avatar
acf
acf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to behold
Pretty sure unsprung weight has more of an effect...
Originally Posted by bbywu
But are you going to notice this on a car that's pushing 3500 lbs?
Old May 18, 2008 | 09:14 PM
  #32
Mycab's Avatar
Mycab is infamous around these parts
many thanks 4 the advice everyone
I just e-mailed the dealer that took my order
Hopefully it won't be too late to get pccb
If not ,big red should be good enough for my time in Europe
When I return to the US next year,I will be ready to mod my car,and can always upgrade brakes as well
Regards and happy motoring to all
Old May 19, 2008 | 02:13 AM
  #33
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Originally Posted by SleeperX
Doesn't anyone care about performance? The PCCBs should make your car accelerate fatster and handle better since the rotors are 1/2 the weight of the regular brakes.
Let me explain this a little further. PCCBs weigh about 1/2 as much as regular brakes. I believe regular 997 rotors weigh 24 pounds, hence you are saving 12 pounds in each corner. 48 pounds of rotational weight is equal to 480 pounds of static weight which is equivalent to about 48hp. I would bet that in a straight line race starting from 0 that a stock 997TT with PCCBs would start to walk away from a stock 997TT without PCCBs.
48bhp due to PCBS brake weight? This was meant as a joke right? I seriously walk away in my 996TT with steel rotors from a 997TT. I have 530bhp @ crank. So how did you figure your equation out exactly because in real life it does not hold water?
Old May 19, 2008 | 04:44 AM
  #34
SleeperX's Avatar
SleeperX is infamous around these parts
You walk away from a 997TT with PCCB rotors. A stock 997TT that is putting out 480hp vs. your 530hp? POssibly driver error if that is the case.
For your viewing pleasure:
Unsprung Weight - Part 2
By: Eric Albert
Introduction
In the first part of this series, we took a look at the effects of high unsprung weight on suspension and handeling. In this part, we will look at rotating mass. Be careful not to confuse unsprung mass with rotating mass. Reducing both is good, but they are not the same. Let's take a look.
Rotational Inertia (or Momentum)
Rotational inertia is a concept a bit more difficult to deal with than unsprung weight. Inertia can be thought of as why a car wants to keep rolling once moving, or remain in place once stopped (unless you forget to set the parking brake on that hill). I believe the terms momentum and inertia are interchangeable. The term “flywheel effect” also refers to these concepts. In a car, there are a number of rotating masses which require energy to accelerate. Up front, ignoring the internal engine components like the crankshaft, we have to worry about the flywheel, clutch assembly, gears, axles, brake rotors and wheel/tire. Out back its a little simpler (for FWD) with just the brakes and wheel/tire contributing most of the mass.
The more mass an object has, the more energy it takes to accelerate it. To accelerate a rolling object such as a wheel, you must both accelerate its mass plus overcome its rotational inertia. As for braking, you must overcome its rotational inertia plus decelerate its mass. By reducing the weight of the vehicle's rotational mass, lightweight wheels provide more responsive acceleration and braking.
Before continuing with our informal analysis here, I want to point out something very important about rotational inertia. We’ve all seen the ice skating move where the skater starts spinning. She pulls her arms in and speeds up, then extends them again and slows down. Why is this? Well, the further a mass is from the center of rotation, the faster it must travel for a given angular speed (how many degrees of an arc it traverses per time unit). The faster anything moves, the more energy it has, so when the arms are pulled in, conservation of energy says that the rotation rate must increase due to equal energy being applied to the same mass over a smaller diameter. Applying this to wheels and tires, which have most of their mass spread as far as possible from the rotation center, I think you’ll agree that it naturally takes more energy to accelerate them. Example: Take a two identical masses, but one is a solid disk of diameter D, the other is a ring of diameter 2D. The ring will require more force to accelerate it (in a rotational manner). Therefore a heavier rim with a smaller diameter could have less rotational mass than a lighter rim of a larger size, and accelerate faster with the same force applied.
The effect of rotating mass can be calculated using Moment of Inertia (MOI). MoI is related to not only the mass of the rotating object, but the distribution of that mass around the rotational center. The further from the center, the higher the MoI. The higher the MoI, the more torque required to accelerate the object. The higher the acceleration, the higher the torque required.
Because of this, the weight of rotating mass such as wheels and tires on a car have a bigger effect on acceleration than static weight such as on the chassis on a car. When purchasing new wheels and tires for a performance car, it can be useful to compare the effects of different wheel and tire combinations. This is especially true when considering upgrading to larger wheels or tires on a car.
The use of light-weight alloys in wheels reduces rotational mass. This means that less energy will be required to accelerate the wheel. Given that each pound of rotational mass lost provides an equivalent performance gain as a 10 pound reduction in vehicle weight, the benefits of light alloy wheels on vehicle performance cannot be overlooked.
For example:
A reduction in the weight of the rim/tire assembly of 5lbs x 4 (all around the car) is equivalent to a 200lb weight reduction in vehicle weight (thats worth 0.200 in the 1/4 mile)
So What's the Point?
The point of this discussion is as follows: There is a great deal of rotational mass to deal with in a car and tires and wheels may only make up half of it. Estimates for weight (o.k. for comparison since they’re all in the same gravity field, therefore the mass would be a similar ratio)
Front: Rear:
Wheel/tire: 30-35 lbs each 30-35 lbs each
Flywheel: 15-20 lbs
Clutch: 15 lbs
Halfshafts: 7-10 lbs each
Gears: 5-7 lbs
Rotors: 3-5 lbs 3-5 lbs
Misc: 3-5 lbs 3-5 lbs
Total: 115-148 lbs 76-90 lbs
So a couple pounds here and there on wheels and tires will make a difference, but that difference is magnified because that weight is placed further from the axis of rotation than any other mentioned (remember the ice skater). All these masses must be accelerated, so any reduction is a good thing. Now you know why we always say don't get those 18" rims for your civic. Not only are the heavier, they have a larger overall diameter. Even with lower profile tires, most plus sizing leaves us with a slightly larger wheel.
Old May 19, 2008 | 07:21 AM
  #35
Mycab's Avatar
Thanks for the detailed and informative reply.
Unfortunately,it was too late to change my order,so I will have to make do with Big red while I am in Europe for the next 6 months.
I will just have to wait till I get back to the US next year,by which time I will probably be ready to give my car a general mod...
One more question though,:if even Porsche may have had some reliability issues with the first generation pccb,how could I be sure of the reliability of components from a smaller after-market shop?just curious
Happy and safe driving to all
Old May 19, 2008 | 10:17 AM
  #36
nzk's Avatar
nzk
nzk is infamous around these parts
care to back up that math with actual fact? there is no way 480 lb of static weight is equal to 48 hp. the car may be a tenth faster (imperceptible to the untrained driver) because its lighter, but how do u make the stretch from weight loss to hp?
also, what are some things that can crack/chip a ceramic rotor? and do the pads last longer? what about pad deposits and vibration?
Old May 19, 2008 | 10:27 AM
  #37
SleeperX's Avatar
I will break out my physics books this weekend. It is my understaning and I have read in many places that 100 pounds is equivalent to about 10hp.
https://www.6speedonline.com/forums/...ad.php?t=71489
In the above mentioned link, it is noted that 300pounds is equivalent to 47hp or about 15.7hp per 100 pounds.
Old May 19, 2008 | 10:38 AM
  #38
gmoney's Avatar
I too have heard 100 lbs is equal to 10hp - not exact science mind you but generally 'accepted' - at least by those who dreamed it up
Anyways, if your penny pinching at the higher levels of the options list simply dont check off the PCCB's. An exhaust and flash + 10 extra minutes washing the car will more than make up for the difference if you have any regrets after the fact.
I decided not to get them and instead invest the $ down the road on aftermarket wheels + other mods. That decision was easy, it was my first Porsche and I had no experience with a PCCB'd car. Might be a different story if I had owned one before with them and noticed the difference. All my searches online showed a lot of people swapping them out and complaing about them, have to admit that freaked me out a bit.
Old May 19, 2008 | 11:06 AM
  #39
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
I really regret not getting the PCCBs but there was alot of availability problems with them during my order. I even saw a GT3RS on the showroom floor of my dealer with no PCCBs presumably for the same reason, availability problems, dunno how true that was. Oh well, next time definitely going with PCCBs.
Old May 19, 2008 | 12:40 PM
  #40
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
Hey Frank, whats up?! How you enjoying your car?
Old May 19, 2008 | 12:44 PM
  #41
SleeperX's Avatar
Chris,
How are you? Ask me that quesiton in 2 weeks? Maybe we could meet up after Memorial Day? Would be good to catch up. How are you enjoying your car?
Old May 19, 2008 | 12:51 PM
  #42
turbojohn54's Avatar
turbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud ofturbojohn54 has much to be proud of
So if I take that weight-saving rule of thumb to the extreme, my TT disappears but I'll have 830 hp.
Old May 19, 2008 | 01:14 PM
  #43
E55AMG's Avatar
Chris,
I'll see you in a few weeks. I love the car. Was on an F430 kick for a couple of months but I'm very happy right now.
Old May 20, 2008 | 01:32 AM
  #44
Terminator's Avatar
By: Eric Albert
Introduction
For example:
Front: Rear:
Flywheel: 15-20 lbs
Clutch: 15 lbs
Gears: 5-7 lbs
Your unsprung weight write up was an insight but I think it was interpreted way too simply. I can’t quite work out nor find the formula of how a 25kg can equal 480 pounds static weight saving you came up with?
http://en.wikipedia.org/wiki/Moment_of_inertia
The simpler approach would go something like this;
997TT; 1580kg/480 = 303bhp per tonne.
Ceramics are 5.6kg per corner lighter but that’s included in the above weight. So are the 18 inch wheels (lighter on a 996TT) versus 997TT 19 inch wheels.
My 996TT; 1540kg/530 = 344bhp per tonne.
Just by having PCBS on your car there is no way you can actually gain 48BHP.
So, back in the real world;
997TT from my friend makes the 100-200kmh run in 8.9 secs.
My 996TT does same run in 7.0 secs dead.
No driver errors.
So it must be those PCBS horses you’ve got are either very hungry or very old and tired indeed?
PCBS are better brakes when hot. Period, no question there. However, they are not as good as steels on the initial bite when cold and are actually less suitable for the street if an emergency situation arises more so if they are wet. They are expensive and racing drivers unless pro’s and or money is no object don’t use them. They produce less dust which is good, but be aware of the first generation as they are not as good – prone to chipping. The bottom line? PCBS are better than steel when hot. However the difference is not night and day. Tests have shown that the stopping distances are similar and I am yet to get fade on my brakes in seriously fast street driving with my steels. However once on the track brakes on a 996TT need to be upgraded whilst the 997TT’s ceramics don’t. But then again the ceramics won’t last you 100K on the track like claimed for the street and the replacement will be very costly. So as always there are horses for courses...
Old May 20, 2008 | 01:49 AM
  #45
20C4S's Avatar
to PCCB, no doubt.
