Engine Revs at startup...
Old May 18, 2008 | 10:37 AM
07turbo's Avatar
07turbo is infamous around these parts
When you start the engine, does anybody else's RPM's jump or rev up.
when its happened the RPM's jump up to between 1500 to 2000 RPM;s .... this is with the clutch pressed all the way and just after the key is turned over.
It doesn't always happen....so i'm having difficulty nailing time the exact circumstance (ie does it happen if the gear is left in 1st or reverse).
I'm curious if anybody's else turbo does this ... if not, i'm might give the dealership a call.
Old May 18, 2008 | 05:31 PM
twnj's Avatar
twnj is infamous around these parts
I'm pretty sure mine always revs to at least 1500 rpm when I start it. Every once in a while (only happened 3-4 times in the past year... completely random as far as I can tell) it will rev to over 3000 and no, my foot wasn't on the gas.
I'm talking about the initial RPM when the key is turned. The engine doesn't stay there; it drops down to around 700 or so (haven't really paid close attention) right away.
Old May 18, 2008 | 05:36 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I too have experienced this on occasion. Stephen Kasper at IA found that his was due to a defective coolant temp sensor that told the ecu to give the wrong startup fuel mixture
Old May 18, 2008 | 07:16 PM
07turbo's Avatar
that's encouraging that i'm not the only one with this issue.
Eclou, so after defective coolant temp sensor was replaced did this solve the problem?
Old May 18, 2008 | 07:32 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Mine does this on occassion, no rhyme or reason to it.
Old May 18, 2008 | 07:51 PM
eclou's Avatar
07turbo I would ask Stephen at IA about the specifics. I have chosen to ignore this as the PIWIS shows no faults on my car
Old May 18, 2008 | 07:55 PM
crd's Avatar
crd
crd is infamous around these parts
Ditto above.
Happens rarely and without obvious cause. Revs to about 2500-3000 then drops immediately to usual idle speed. A little disconcerting, but probably not a real problem.
Old Jul 7, 2009 | 02:58 PM
MJS NYC's Avatar
MJS NYC is infamous around these parts
Bumping this thread, as I have had this happen intermittently for no reason whatsoever. Anyone find a solution?
Old Jul 7, 2009 | 03:40 PM
RT-TURBO's Avatar
RT-TURBO is infamous around these parts
FYI this isn't a problem confined to Turbos, visit the other forums 997c4s etc all have this trait. Not sure the cause but unsettling to dry start a motor taking it to 2500 or 3000 rpm's even for a short while. No answers here just misery loves company. Rt
Old Jul 7, 2009 | 06:08 PM
summoboy's Avatar
summoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nice
same issue. did not have this happen on my 997S..??
Old Jul 7, 2009 | 06:25 PM
Tiger's Avatar
Tiger is infamous around these parts
oh yea, Rpm jumping on start up .this happened to me. either you have a vaccum leak or your Throttle valve needs cleaning. took mine to the dealer and they cleaned the throttle valve now all is good and RPM stays stable
Sep 10, 2015 03:20 PM
Sep 1, 2015 03:16 PM
Aug 20, 2015 12:17 PM
