Any experience with these clear bulbs?
Anybody have any experience with these clear bulbs?
http://cgi.ebay.com/ebaymotors/Parts...3286.m14.l1318
with that type of chrome coating you will seriously reduce your signal performance. best to go for a osram diadem of philips silversion type. hides the yellow 80% or so but also keeps all the safety of the lamps performance.
With these chrome ones you get maybe 30% illumination performance i.e. no one will see your lane change intentions.
http://www.osram.com/osram_com/Consu...DEM/index.html
http://www.powerbulbs.com/ global shipping etc.
7507 for rear indicators is what your looking for. I prefer the diadem type but not easy to find.
For clear markers (assuming you hbave euro ones installed) go with the hoen chromium www.hoen-usa.com/cr.htm
Another consideration is those bulbs get about as hot as the sun. They are fine for turn signals but replacing bulbs that are on for any extended periods of time can lead to significant problems. Several people have used those in non-Porsche application and melted their bulb sockets and/or housings.
changing out the turn signals and side markers is fine, bulbs run just as cool as stock. xenon look ones are a different story, and the cause of melting issues, not these guys above.
blue glass tint acts as a yellow light filter thus retains heat, if the housing is too small it will cause the soft plastics to give way.
Has anyone tried the new Hoen Chromium for rear tail lights?
http://www.hoen-usa.com/cr.htm
Hopefully they are reliable and don't burn up harness?
LiquidElephant
Aug 27, 2015 06:17 PM
