whats the average boost people are getting on TT's
Old Aug 7, 2008 | 05:43 PM
skyytek's Avatar
skyytek is infamous around these parts
Whats the average boost everyone is getting for stock 2008 TT"s in sports mode and when you floor it. ?. Mine hovers around 11/12 on the readout ?. I could have sworn when I first got it - it was hovering around 15/16 - but not sure ?. what could be causing this ?. or am I mistaken ?.
Old Aug 7, 2008 | 05:52 PM
Vic55's Avatar
Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !
1.2 bar consistently but its an 07 ...
Old Aug 7, 2008 | 06:55 PM
skyytek's Avatar
whats the calibration on the 997tt 08. it goes from 0 to 20 or something. is 10 - 10 pounds or 1.0 bar ? - now you have me confused - does your 1.2 = 12 on mine ?.
Old Aug 7, 2008 | 07:39 PM
crd's Avatar
crd
crd is infamous around these parts
Sky,
You can set the readout to be in either bars or psi. You can also set the display to be numeric or sliding bar graph. I like psi personally, and I leave the display on numeric readout.
The boost pressure displayed will depend on lots of factors, not just throttle position (ie WOT). Ambient air temp and thus density play a big part in how much boost is dialed up at full throttle, as is engine load, like going up a slight grade.
With SC on, I have seen up to 17-18 psi at WOT.
Old Aug 7, 2008 | 08:39 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
At WOT, I usually hit 17-18 PSI. With the Evoms DV's, it stays there until I let off the pedal.
Old Aug 7, 2008 | 11:46 PM
skyytek's Avatar
okay - what would cause mine to be only 10-12psi in that case ?.
btw. what is WOT ? pardon the ignorance there.
Old Aug 7, 2008 | 11:49 PM
skyytek's Avatar
okay - what would cause mine to be only 10-12psi in that case ?. it seems a little low compared with what everyone else is reporting at WOT.
Old Aug 8, 2008 | 05:43 AM
bbywu's Avatar
The PSI/BAR measurements from the on dash computer are pretty inaccurate. I've personally seen a difference of at least 2-3 PSI from a manual boost gauge.
Old Aug 8, 2008 | 07:24 AM
tblountman's Avatar
tblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond repute
WOT = Wide Open Throttle
Old Aug 8, 2008 | 08:55 AM
OT997's Avatar
OT997 is infamous around these parts
VTG telemetry
As I understand it, with variable vane geometry the gauge is not entirely precise (as it was in the 996 TT). At WOT in 2nd, 3rd and 4th you should be at 17 or maybe 18 psi. With my mods I'm running about 21 psi according to tuner Tym .
Old Aug 8, 2008 | 11:21 AM
vtandon's Avatar
vtandon is infamous around these partsvtandon is infamous around these partsvtandon is infamous around these parts
I see .9-1 bar in non sport and 1.1-1.2 in sport. Turn sport on and keep the throttle wide open. Make sure you are at 2700-3000 rpm to see those numbers. It starts falling off around above 4k.
Old Aug 8, 2008 | 11:50 AM
noah677's Avatar
noah677 is infamous around these parts
Skyytek
You really should read you manual where it gives all the figures. With a simple chip and mufflers change you get about 3+ psi extra in sport mode ( and some in the non sport mode,) but that can depend on how your ecu was/will be flashed. Your numbers seem in the ball park
Old Aug 13, 2008 | 05:37 AM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
mine shows 1 bar on normal and 1.2 in sport mod
Old Aug 13, 2008 | 08:53 AM
gmoney's Avatar
what gear are you all taking this measurement? I noticed in 1st geat I see up to 12 and in 3rd up to 18 - both sport mode on.
Old Aug 13, 2008 | 09:13 AM
hotsauce's Avatar
hotsauce is infamous around these parts
1 bar=14.7 PSI
