997TT front spoiler, rockers and rear valance removal...
Old Aug 24, 2008 | 04:23 PM
tssci's Avatar
tssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to behold
I want to paint these three items to match the color of the car and am having a heck of a time trying to remove them. There is clearly some trick and or tool to release the clips/tabs that seem to be holding with a death grip. All the screws have been removed - just the clips holding everything in place....anyone done this and know the secret??? Thanks!
Old Aug 24, 2008 | 07:10 PM
oc997's Avatar
oc997 is just really niceoc997 is just really niceoc997 is just really niceoc997 is just really nice
just be careful and be patient. You have to pull it at a certain angle.
Old Aug 25, 2008 | 06:54 AM
tssci's Avatar
more information???
Thanks for your reply, but the 'certain angle' thing is what I'm asking about. If you've done this successfully, can you be more specific? Thanks!
Old Aug 25, 2008 | 08:23 AM
lintc0532's Avatar
lintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond repute
I think to remove the rear valan,you will have to remove the whole rear bumper.rear valan and the intercooler back cover seems in one part.
Old Aug 25, 2008 | 08:59 AM
bluesea's Avatar
bluesea is infamous around these partsbluesea is infamous around these parts
+1
I had trouble getting leverage to pull down and backwards if thats the way.
Old Aug 26, 2008 | 07:17 AM
meaker's Avatar
meaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to behold
The front spoiler should have 2 screws at each end(near wheel) and then it should just pull away from the car. Don't know about the rest..
Old Aug 27, 2008 | 09:46 AM
GEE-BEE's Avatar
GEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of light
Thumbs up ?
ROCKERS: Torx screws , two under the rear inner fender splash guard
Pull out and down , put the clips in back in the rocker and attach the same way..
Gee-Bee
Need help we can chat ?
Old Aug 28, 2008 | 05:53 AM
tssci's Avatar
More clarification...
GEE BEE - thanks for the most helpful response. Can you further clarify what you mean by pulling 'out and down'? Do you mean removing all the screws and then pulling the cover straight towards you/away from the car? Thanks!
Old Aug 28, 2008 | 08:48 PM
bluesea's Avatar
Thumbs up
Thanks Gee Bee,
Next time I'll persevere with that method which I believe I was doing (though I erroneously described my action differently above). I was pulling out and curling down, backward.
I ended up splitting the lip's slotted tabs as I pulled. I didn't mind as I was throwing the old lip away.
I was having trouble getting enough leverage as my car is lowered and I was in a tight space.
Thanks again!
Old Aug 28, 2008 | 09:49 PM
GEE-BEE's Avatar
Thumbs up Lowered
I drive mine up on small wood blocks so I can get a jack under my GT2 Rockers on TT
Your Welcome !.....
If I need to get to the exhaust I have 3 " blocks that I set the tires under after I lift it...
Gee-Bee
Old Aug 29, 2008 | 01:40 AM
bluesea's Avatar
I'll have to put aside a set. I did that once with my lowered M5 after an oil filler cap slipped down into the abyss and I retrieved it via the oil pan change door in the under cowling.
Great wheels btw! That's sad (for us all wanting to paint the lip, actually) that you're going to have to revert to an unpainted front lip. Your TT looks so righteous!
Old Aug 29, 2008 | 09:26 AM
atomic80's Avatar
When I had mine removed, we used a plastic screwdriver to pry the front spoilers off pulling outwards. The rear valance also has a metal piece in the center that would have to be removed. You'd have to use two rivet pieces again.
Jul 29, 2019 11:13 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
PenguiN
Nov 12, 2015 05:24 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
TrackOne
Aug 20, 2015 12:56 PM
