Anyway to leave non-sport throttle response while in sport?
Old Oct 11, 2008 | 06:05 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Two things drive me crazy about the turbo.
The first is the throttle response in sport. It is so sensitive I find it hard to drive the car smoothly. I just want the overboost and no change in throttle response. Is there a way to stop the change in response so that it is just like when it is in non-sport mode. Can the dealer turn this "feature" off? One reason I won't get an aftermarket software program is because they make the throttle even more sensitive! Forget that!
The second is the auto up on the passenger window. You have to hold it until the window is halfway up for it to continue in auto. It is so stupid. It might as well not even have auto up. Can this be programmed to go auto up from the bottom?
Thanks.
Old Oct 11, 2008 | 07:36 AM
bbywu's Avatar
Thanks.
No and no.
For the second issue, you could purchase a remoteKey...a few here have installed it. There is no setting on PCM or that PIWIS that can resolve the issue...https://www.wit-usa.com/sms/shop/ind...oducts&cat=152
Old Oct 11, 2008 | 07:47 AM
jhbrennan's Avatar
Thanks.
Aftermarket ECU programming doesn't make the throttle more sensitive.
Old Oct 11, 2008 | 07:49 AM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
You can make it more sensative if you want through aftermarket. I honestly can't tell the difference between non-sport and sport mode.
Old Oct 11, 2008 | 08:10 AM
Periokid's Avatar
I few advertise that it does.
Old Oct 11, 2008 | 08:11 AM
Periokid's Avatar
You can't tell? Really? Mine is a huge difference.
Old Oct 11, 2008 | 08:23 AM
infanterene's Avatar
infanterene is infamous around these parts
Mine is too sesative in Sport too, especially in first gear. Maybe I am getting old.
Old Oct 11, 2008 | 08:35 AM
Periokid's Avatar
Yeah, I guess I am becoming a geezer too.
Old Oct 11, 2008 | 12:38 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
I notice the throttle response difference also, IMO it's a pretty noticeable difference. Now I'm no tuning wizard, but I'm guessing it's from increased timing when sports mode is on. If there's a way to do a full custom tune, then one should be able to play around with the timing from idle-3k to make taking off/stop & go driving more smooth.
Old Oct 12, 2008 | 12:26 AM
THE STIG's Avatar
THE STIG is infamous around these parts
It's not due to timing being increased, but with the throttle body opening more with less pedal, giving you a better reaction time if on a track for example.
Old Oct 12, 2008 | 12:47 AM
vtandon's Avatar
vtandon is infamous around these partsvtandon is infamous around these partsvtandon is infamous around these parts
No difference for me, if anything I want it more responsive.
Old Oct 12, 2008 | 11:40 AM
Vic55's Avatar
Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !
I might be in the minority here or because my M6's ECU modded throttle is insane, but I find the 997TT Sport throttle to be spot on.
Old Oct 13, 2008 | 08:06 AM
Periokid's Avatar
The response is fine once cruising, but in stop and go traffic it is a pain in the a$$.
Old Oct 13, 2008 | 08:52 AM
gmoney's Avatar
Huge difference, takes some time to get used to its responsiveness but now I drive with it on 100%. With it off it feels like a Honda Civic.
Use it a lot, you will get used to it. Car feels so much more lively with it on.
Old Oct 13, 2008 | 09:50 AM
ALPINE_997's Avatar
Thats really strange as I never have noticed a difference. I will have to do some tests to make sure that something is not wrong with it
I know my boost holds in sport so that part much work. The response is not much to me.
