GIAC Reliability Again
Old Oct 29, 2008 | 01:49 PM
il nino's Avatar
il nino is infamous around these partsil nino is infamous around these parts
I guess there is no positive feedback on the reliability of the GIAC software. I put a thread out a few days ago and there are no replies as of now. I have a daily driver and need high reliability. Has anyone had any bad reliability with a GIAC chip in their car? I would have the work done at AWE but I live 2 hours away and don't want to think of dealing with problems with help that far away.
Old Oct 29, 2008 | 01:59 PM
gmoney's Avatar
Outside of a cruise control issue -which I dont think was even attributed to the flash per se - Ive never heard of problems on a flashed TT.
Dont want anyone to assume that because no one responded a problem is there, but if you are at the least a bit concerned about reliability then modding may not be for you, perhaps consider an exhaust (if you have not done so already) and 'easier' on the car mods.
More boost will tax your car and its to be expected that wear and tear will increase vs. stock. Small price to pay for the gains though.
Old Oct 29, 2008 | 02:13 PM
paneraiwatches's Avatar
paneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to behold
I've had GIAC program from day 1. Never an issue with reliability, not once. Go for it!!
Old Oct 29, 2008 | 02:20 PM
Josh/AWE's Avatar
That is correct. Those cruise issues were coming from when a client would introduce a new computer into the car, not the programming. For example, a customer gets a new computer from the dealer to be flashed so they could keep the original computer stock. That is when problems would occur. Personally I don't feel having a second computer is totally necessary since G.I.A.C. has the ability to toggle between stock and pump modes.
You don't really belive that, do you? Adding an exhaust for example lowers your EGT's. This was monitored and recorded with a scan tool. Lower EGT's means less stress on your turbos.
These motors are VERY overbuilt for the power level. That is why big hp numbers can be obtained with a few bolt on mods and bigger turbos...
Old Oct 29, 2008 | 03:54 PM
ginger_snaps's Avatar
ginger_snaps is infamous around these parts
with proper mods those stock turbos can handle allot, a GIAC chip wont effect anything or cause serious "wear & tear" not anymore than daily driving it hard all the time would. I have GIAC in my Gti and have never had a single issue. Now for others such as APR Performance or REVO that's a different thing.
I have friends running APR who have had fuel cuts and a few issues here and there and with revo i had a friends who's car went into security mode, but that was the fault of the fact we took the battery out to install a electronic boost gauge and the chip re-set the ecu. Revo runs the hardest out of all the chips.
There's people who will be for one chip over another. One issue with APR i have seen is APR's chips turn certain stuff off in your car, the chip finds things that are meant to prevent certain things in your enginge from doing a certain function and the chip swithces those mechanics off in order to gain performance, yeah your gaining HP but at what cost? Giac is the one in the middle, not the most aggresive chip but not the least either, and runs the best IMO. There should be no issues at all with a daily driven 997tt with a chip.
Old Oct 29, 2008 | 04:41 PM
SoCalCFP's Avatar
SoCalCFP is infamous around these parts
with an exhaust and the giac ecu what hp does one pick up over stock with 91 and 93 octane. i ask about 91 as that is what we have in California.
Old Oct 29, 2008 | 09:10 PM
TT Surgeon's Avatar
I went to PES (check out the web page on the right>)
Tony did a custom flash for me, he has a new 7500 ft facility and is very user friendly.
I've never heard of any issues with giac either, unless they are more cookie cutter than a custom system(?). Either way, you should be fine. Don't get a second computer and try and 'trick' porsche, the time/miles/etc will never match up and you will surely be ****ed in a warranty issue, vs not trying to conceal your flash. Fraud is worse than ignorance here, imo. My dealer knows all about my flash, never been an issue, of course I've never claimed anything big either.
I saw on another board where a guy in the midwest with a 800hp system, blew his motor to peices, tried to cover it up by going back to stock, pcna turned him down flat, 40k later......
Old Oct 29, 2008 | 09:16 PM
bbywu's Avatar
What are you really asking in terms of reliability?
Are you asking if the flash upgrade is going to damage your ECU?
or
Are you asking if the flash upgrade is going to cause damage to your car?
or
Are you asking if the flash upgrade is going to void your engine warranty?
The answer to the first question is no.
The answer to the second question is probably not, unless you seriously abuse your car.
The answer to the third question is probably yes, unless your dealer is mod friendly.
Old Oct 29, 2008 | 09:18 PM
bbywu's Avatar
Dyno numbers suggest anywhere from 60-90 HP depending on your baseline. However, don't get caught up in the dyno game.
Old Oct 29, 2008 | 09:22 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I have had GIAC programming for both the stock turbos and the upgraded 700 kit turbos. No issues whatsoever. I have never read of a drivability issue on a 997tt with GIAC. I have run mine extensively on the track, for standing mile top speed runs, and sitting in 100F+ Texas rush hour standing traffic. It is flawless
Old Oct 29, 2008 | 09:25 PM
bbywu's Avatar
And let us all say our final prayers to the end of the line for this current engine block.
RIP.
Old Oct 29, 2008 | 09:27 PM
SoCalCFP's Avatar
sounds good to me. i wont dyno the car, just want to make sure i am sure of getting the performance upgrade.
Old Oct 30, 2008 | 02:42 PM
noah677's Avatar
noah677 is infamous around these parts
no problems with the flash and tubi mufflers for a year. The gain was and is awesome
Old Oct 30, 2008 | 02:44 PM
gmoney's Avatar
whats is the going rate on the GIAC flash nowadays?
Old Oct 30, 2008 | 06:10 PM
my dealership offers the chip, luckily i live down the road from Champion Porsche
