Keithta Porsche 997 Turbo VS Modded 07 GSX-R1000, Viper w/150 Shot NOS & ZO6 (VIDEOS)
Old Nov 24, 2008 | 08:13 PM
keithta's Avatar
keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !
Since my performance related problems have been resolved, we decided to take my car out to a drag race meet on Friday night. Unfortunately, the area where these videos were taken were in a location without ANY lighting. It was literally pitch black, so the video quality is poor. Not to mention videos should always be shot from the car who is trailing so you can get a clear view of whats happening ahead. Nevertheless, we did the best we could.
My car was on 20" wheels for these runs. Too lazy to change to the 19s. Car was running MS109 (105 octane unleaded) with boost set between 1.37-1.4 bar. (20 psi)
Here are the vids:
Race 1)
2007 GSXR1000
Mods:
Modded Air Box
BNC Filter
Throttle Body Billets
Power Comander
The bike asked for a 70 mph roll since he said its too difficult to keep the front end down if we started any lower. 2 people in the Porsche.
Also raced a 2004 GSXR1000 with a pipe and power commander as well (no video) we beat him pretty easily from a low speed roll. The 2007s GSXRs are much faster...
Heres the Video against the 07 GSX-R1000:
http://www.youtube.com/watch?v=-CxsQQ43_KY
Race 2)
2007 Corvette C6 ZO6
Mods: Stock
This ZO6 was beating up on a couple of modded turbo and Cobra mustangs and asked me to run so we went for it.
65 roll. 2 passengers in each vehicle to keep weight even.
Video:
http://www.youtube.com/watch?v=G-ZIdKQZeKU
Some time ago, I previously ran a different stock C6 ZO6 where the video is much clearer. In this video my 997TT was putting down about 50 whp less coupled with some technical problems but you can still get a clearer picture of how the two cars measure up. Some of you may have already seen this:
http://www.youtube.com/watch?v=PRvrOMgau4k
Race 3)
2006 Dodge Viper GTS
Mods:
Exhaust
Air Intake
Computer
150 Shot of Nitrous
Did 3 roll races:
1 at 40 mph, 1 at 65 mph, and another at 80 mph.
2 passengers in each vehicle as well.
Video:
http://www.youtube.com/watch?v=vKfUxDI9Y7U
Old Nov 24, 2008 | 08:16 PM
bbywu's Avatar
Whooaaaaaa...jeez that's fast....
Old Nov 24, 2008 | 08:51 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Just wanted to say that car is well sorted!
Robert
Old Nov 24, 2008 | 10:02 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
laying waste to some tough competition. Very impressive
Old Nov 24, 2008 | 10:05 PM
Dr_jitsu's Avatar
How are you getting 750 awhp out of a stock fuel system?
Old Nov 24, 2008 | 10:11 PM
keithta's Avatar
997TT come with 60 lb. injectors from the factory.
All of Protomotives 997TTs that are running at the 700 whp level including the Tip he just completed thats putting down 710-ish awhp are all running safely off the stock fuel system.
Old Nov 24, 2008 | 10:21 PM
AudiRS's Avatar
AudiRS is infamous around these parts
Amazing car considering its 4wd and has 20inch wheels.. glad you got everything sorted out.. Why did you retain stock headers?
Old Nov 24, 2008 | 10:24 PM
Dr_jitsu's Avatar
I just got through reading your build thread...yes 60lb injectors and more efficiency is why. I expect a 5.9 60-130 on my car but your time will be very very hard to match.
Old Nov 24, 2008 | 11:15 PM
keithta's Avatar
Dr_jitsu:
From the 996TT, I defienetely know that Porsche made a handful of changes on the 997TT that helped out with efficiency:
Larger injectors
Lower Compression ( to handle heavier boost loads) Reduced the compression ratio from 9.4:1 (996TT) to 9.0:1 (997TT).
VarioCam in the 997TT also changes both the valve lift and duration of the intake valves. Theres an adjuster infinitely varies the relative position of the camshaft versus the crankshaft throughout a wide range. So the cam setup is definetely different.
Also measured the 996 and 997 TT thottle bodies:
997tt: 77 mm stock
996tt: 68 mm stock
Might have been off a milimeter +/- but I got it as close as I could.
In comparison with the previous generation (996) Turbo engine, the adjustment stroke range of the intake valves was increased from 3.0 to 3.6 mm. This allows the engine to cover a wider engine-speed and load range, with the small valve lift openings which helps efficiency and power.
Im sure there are a number of other things that were changed that were not even published.
By the way, I had an opportunity to view a 996TT and 997TT head on a work bench next to each other and they both look identical (port sizes, valves, and external structure as well) So unless there are differences beyond the ports outside the scope of what I can see, I believe the head design are virtually the same on both cars.
Im looking into upgrading the heads & cams a bit deeper now and once a combo is put together I will build my motor and up the turbos. Then secure whatever else is needed to meet or exceed the 1000 hp mark reliably.
In the meantime, having fun with the current setup.
As for your car, I am certain you will dip into the 5s. Keep us in the loop...
Keith
Old Nov 24, 2008 | 11:23 PM
keithta's Avatar
Thanks...
I retained the stock headers because Todd has a number of 800+ whp 996TTs still running them. Todd seems to prefer the TQ curve of the stock headers compared to the modified headers (depending on the application of course). When I up to the 35Rs I may go larger.
Keith
Old Nov 25, 2008 | 12:11 AM
Divexxtreme's Avatar
Great job, Keith. Your car is f'ing quick, bro!
AudiRS - I also kept the stock headers on my car all the way to the 1,050 crank HP level.
Old Nov 25, 2008 | 01:57 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Thumbs up
Impressive performance.
Old Nov 25, 2008 | 02:03 AM
Q8_TwinTurbo's Avatar
Q8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud of
Great runs. Great car. Unbeleivable power.
Enjoy your ride safely.
Old Nov 25, 2008 | 02:56 AM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Holy moly!!!!!!!!! That is too fast!!!!!!
Congratulations keith!!!
Old Nov 25, 2008 | 03:55 AM
snakebitten's Avatar
snakebitten is a splendid one to beholdsnakebitten is a splendid one to beholdsnakebitten is a splendid one to beholdsnakebitten is a splendid one to beholdsnakebitten is a splendid one to beholdsnakebitten is a splendid one to beholdsnakebitten is a splendid one to behold
Great runs man...Nasty Turbo you have there.
