Need help.......
Old Feb 28, 2009 | 03:23 PM
nyamg's Avatar
nyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud of
Need help.......
I just installed my exhaust, took the car for a spin and the CEL came on also I'm not making any boost???? Can anyone help please?
Old Feb 28, 2009 | 03:47 PM
Neeeenja's Avatar
Neeeenja is a jewel in the roughNeeeenja is a jewel in the roughNeeeenja is a jewel in the rough
happened to me before I got new cats could be the CATS.
Old Feb 28, 2009 | 04:41 PM
nyamg's Avatar
is it possible for brand new cats to be bad???
Old Feb 28, 2009 | 05:13 PM
TT Surgeon's Avatar
yes.
go to sears right now and pick up the portable code reader, it will tell you what codes are bad, as well you can reset everything. Another option is to disconnect the battery and reconnect it, that will reset the ecu.
Could easily be the cats, but make sure nothing is loose, disconnected, trace the o2 sensor wires make sure they're not touching/grounding anywhere near a pulley, etc, we had that once.
Worse case pm me I have a code reader and we can trouble shoot it this weekend.
c
Old Feb 28, 2009 | 05:44 PM
nyamg's Avatar
I checked all hoses and connections everything seems to be connected, the car was making a weird wooshing type noise, hard to explain plus very little boost. I left it at the shop and will go back tomorrow to check it again.
Old Feb 28, 2009 | 06:49 PM
jc767's Avatar
jc767 is infamous around these parts
my buddy got a code reader to figure his issue out- good luck.
Old Feb 28, 2009 | 06:53 PM
gmoney's Avatar
interesting. are all o2 sensors installed correctly? which exhaust?
Old Feb 28, 2009 | 09:27 PM
TT Surgeon's Avatar
Did they take the bumper off? Easy to dislodge a boost hose, etc.
I believe it's a fvd, their stuff is usually pretty good.
Old Feb 28, 2009 | 10:06 PM
nyamg's Avatar
Bumper and intercoolers came off, can you get to the 02 censors with taking the intercoolers off?
Old Mar 1, 2009 | 07:33 AM
TT Surgeon's Avatar
I've done exhausts on/off my car about 4 times and I've never taken off either the bumpers or ICs.
The money is on the ICs a bad cat wouldn't light up for 30miles or so as the o2 sensors recycle. An immediate cel is installation related 99% of the time.
Call me later
C
Old Mar 1, 2009 | 08:12 AM
nyamg's Avatar
I will, thank you again.
Old Mar 1, 2009 | 08:23 AM
lintc0532's Avatar
lintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond repute
If you not making any boost then it means your ECU in limp mode whichs reduce power...An O2 sensor error won't active limp mode.You should still have power.So check the intercooler hoses for leakage or other wire/conectors you touched while the exhaust installation.
996TT-SANTORINI
May 7, 2009 12:24 PM
