Randy Probst driving APR 997 Turbo
#46
I'm still scratching my head to how a ECU + exhaust tune on race fuel to provide a 200hp boost on a stock VTG with no wheel changes. Doesn't that exceed the maximum flow that the stock compressor wheel is capable of? I thought the stock VTG was capable of 600-650hp (depending on flow rate and turbine efficiency.)
#47
So let me get this straight. The hp gain with exhaust and ECU tune on 91 pump gas is an increase of 53 hp? That sounds more reasonable. That is in line with most other ECU tunes out there.
#48
On 91 octane, yes. APR is one of the few companies that actually recalibrate the entire program from the ground up for each octane of fuel commonly used. Other companies say the ecu adapts to different octane and yes that is true but only to a small extent. A true octane specific calibration will always yield more than the ecu can adjust itself too and the APR power really outpaces the competition at the higher octane levels. Drive the 91oct and feel like you are chipped on par with other companies but then add some race gas and get chipped all over again!
<O
Regarding the way they make their power, I’ve asked the engineers at length why they think other tuners aren’t making the torque and they relay other tuners must not know how to control the vgt’s. APR is able to recalibrate the turbine positions at different points in the power band resulting in all of that extra torque. It seems other companies may be calibrating the 997TT like a 996TT and haven’t determined how to take advantage of the new technology. The 997TT uses Bosch Motronic 7 engine management which was first released in Audi in 1996. APR has been working with Bosch ems exclusively since 1997 and they have a pretty strong prowess regarding a complete understanding of the ems.<O></O>
<O
#49
I love the torque that APR unleash's in their software. I have a turbo coming in at the end of the month that wants to switch from GIAC to APR because of the amount of fuel GIAC is running it's starting to change the color of his rear bumper. I will post little write up with videos in a week or two when he comes in.
#55
What color is his car & what change in color? What exhaust does he have? And the change in color is PROVEN to be from the "amount of fuel GIAC is running"?
#56
i wana besure from someone tried the APR tune
#57
With all due respect for a pro and a sponsor, this has got to be one of the strangest reasons for criticismm of a tune I've EVER seen. Would you please expand on this?
This is assuming that he meant this, since it's really the only legit explanation I can think of.
However there are plenty of stock vehicles that can spit flames, especially when the cats are altered or removed. So while this is possible, a little more detail would be helpful.
#58
If I am not mistaken I believe they run less boost but achieve greater torque than the other brands. I believe I read it somewhere but can't remeber.
#59
Check this video out. The car has software and exhaust. The thing makes 700lb/ft of torque with just the chip and 100 octane.
997 Turbo Video
997 Turbo Video
