IPD Y-Pipe
Old Apr 8, 2009 | 06:15 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
I have the stock TB with the 74mm IPD Plenum. Your car and mine have the same power mods with the exception of the different exhausts.
Don't quote me on this, but I don't think the price is a whole lot more than the Plenum.
Old Apr 8, 2009 | 07:02 PM
CWtwin's Avatar
CWtwin is a jewel in the roughCWtwin is a jewel in the roughCWtwin is a jewel in the rough
I got the AWE 750r kit last week. It is crazy! You wont regret it.
CWtwin
Old Apr 9, 2009 | 12:04 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Is the IPD plenum-----IPD Y pipe the same thing???
thanks for sharing
Old Apr 9, 2009 | 01:53 AM
jiaim's Avatar
jiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to all
the plenum is the small part you put after the throttle body
the y pipe is the large y shaped part which seats at the back of the airbox and connected to the intercoolers.
does rss have in the works the ipd plenum + gt3 81mm TB + Y PIPE mated together ?
Old Apr 9, 2009 | 01:58 AM
GotBoost?'s Avatar
Originally Posted by jiaim
the plenum ils the small part you put after the throttle body
the y pipe is the large y shaped parts which seats at the back of the airbox and connected to the intercoolers.
No sure. You might want to call them.
Old Apr 9, 2009 | 02:47 AM
GotBoost?'s Avatar
Here is the dyno chart.
Old Apr 9, 2009 | 04:20 AM
milou's Avatar
does anyone have pictures of plenum installed and Y pipes installed?
The stock plenum and pipes is one piece (correct me if i'm wrong) how can you just add plenum with stock pipes?
Old Apr 9, 2009 | 04:22 AM
milou's Avatar
So you do all this power on the wheels?????
Old Apr 9, 2009 | 08:21 AM
QUIK 911's Avatar
QUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to behold
Hey Gotboost, your car has some crazy torque. I've had my car dynoed several times and your plot for horsepower looks completely different. My torque was not as high as yours (540) but my horsepower would increase until the end where yours peaks early then drops off. I'm not an expert but maybe your ECU/DME is detecting the heat due to lack of fans and is retarding time and reducing boost because it is detecting some knocking? I had similiar mods and I remember this happening to my car once. I have the GIAC tune and made around 485 to the wheels on their dyno.
Old Apr 9, 2009 | 10:58 AM
GotBoost?'s Avatar
I htink you are spot on. I think a better cooling system would of resulted in a different looking plot.
Old Apr 9, 2009 | 10:59 AM
GotBoost?'s Avatar
Milou,
Yes. The dyno is power measeured to the wheels. The plenum and Y-pipe are 2 different pieces before and after the TB.
Old Apr 9, 2009 | 12:37 PM
QUIK 911's Avatar
Maybe the next step for you is the intercoolers to keep intake temps down so your ECU doesn't have to pull timing. You should get something to thing to check your intake temps while your driving. I've seen it first hand that stock intercoolers cannot do the job because your car is making to much power to keep up. By any chance, you going to C&C Saturday?
Old Apr 9, 2009 | 12:42 PM
Josh/AWE's Avatar
Let me know what you think. I've been thinking about getting this to add to my AWE 750 kit. I'd also like to see the pics when you get a chance
RT,
We use a larger throttle body with our kit and a special machined T pipe that fits it. Please retain that and do not install anything else.
We don't want to jeopardize the performance. I also don't even think it will work due to it's size.
Thanks!
Old Apr 9, 2009 | 12:55 PM
bbywu's Avatar
+1 on funny looking plot...are you losing boost at WOT?
Old Apr 9, 2009 | 01:19 PM
QUIK 911's Avatar
Originally Posted by Mike/A.W.E.
RT,
Thanks!
Understood
