Tire Pressure of 36/44 PSI too high?
Old Apr 13, 2009 | 06:45 PM
cannga's Avatar
Originally Posted by bli8
I also noticed the TPMs reads quite low compared to my gauges. I double checked the reading using two different good quality gauges this morning and both read 33F/39R cold. Then when the reading come on, TPMS only showed 29F/35R, off by 4 PSI both F and R. Do your TPMS readings agree w/ your tire gauges?
Using a reference level tire gauge http://www.longacreracing.com/catalo...id=982&catid=8 , my TPMS system consistently reads about 1 lower. One could argue I then should set the differential reading to be minus 1; and that's what I do, roughly, between 0 and minus 1.
If yours are minus 4 both F & R, then either your tire gauge is off, or the 4 TPMS sensors are off. Since it's statistically unlikely for the each of the monitor to be off by such similar large amounts (assuming that the rest of the system is fine -- very likely?), I would guess/speculate your tire gauge is off. Just guessing and if I don't make any sense at all, I understand.
Tiago,
See Doug's response (TT Gasman) above regarding tire pressure at the track. Or PM him.
Old Apr 13, 2009 | 10:41 PM
bli8's Avatar
bli8 is infamous around these partsbli8 is infamous around these parts
I first thought it must have been my gauge, so I pulled another gauge - both pretty good quality Moroso gauges but definitely NOT reference quality, but both read within half PSI of each other and both read 3 PSI (not 4) higher than the TPMS reading. I'll have to borrow another tire gauge and double check but would like to hear from more people who have compared their TPMS reading to their gauges.
Old Apr 13, 2009 | 11:22 PM
JCNPB's Avatar
JCNPB is infamous around these parts
Your results are the same as mine (TPMS consistently reads 3 psi too low at all four tires) and I have used three or four high quality tire pressure gauges.
Old Apr 14, 2009 | 01:01 AM
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
Tiago,
I will start with 30-36 cold, and then after each session, i will monitoring the pressures till it reach the maximum of 36-44 on track, as Doug advice. After the trackday, I will post here the cold pressure to reach that goal on track.
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
