wheel spacers
Old Apr 15, 2009 | 10:28 PM
997tt RS 2.7's Avatar
997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of
Question wheel spacers
just had 997tt lowered (Champion H&Rs also used their sways). would like to "push" out wheels a little without causing "rub" or changing rims (OEM turbo rims). are OEM 5mm spacers enough all around or go wider? can you do asymmetrical front/rear? can anyone advised width for front/rear for max "look" without causing "rub"? reply greatly needed
Old Apr 16, 2009 | 04:36 AM
scont07tt's Avatar
scont07tt is infamous around these parts
how far did you drop it?
Old Apr 16, 2009 | 10:26 PM
dropped it about 1in maybe 1.5 after settleling front & rear.
Old Apr 16, 2009 | 11:26 PM
bli8's Avatar
bli8 is infamous around these partsbli8 is infamous around these parts
1.5, wow, that's a lot. Any pix?
Old Apr 17, 2009 | 02:45 PM
sorry misspoke probably 1in total after settlement? i am not sure; i went with Champion H&R springs and sways. is OEM 5mm spacers sufficient? different front/rear widths? i have stock turbo rims. please advise
Old Apr 20, 2009 | 05:38 PM
cgng30's Avatar
cgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to behold
i am in the same boat, havent decided yet. I just finished installing techart springs. I have a set of OEM 5 mm spacer kit w/long bolts from my 997 c2, i know they will fit the turbo, had confirmed with sharky.
Old Apr 20, 2009 | 06:20 PM
if you go with 5mm OEM spacers please post or send me a PM. thanx. dealer tech advised that 5mm OEM is sufficient and that alot of R&D went into choosing that size with the stock rims.
Old Apr 21, 2009 | 09:11 AM
cgng30's Avatar
will do. i still need to test drive the car after the spring install. as it has been crapy here in chicago.
Old Apr 21, 2009 | 02:52 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
On a previous post sharky from sharkwerks suggests 7mm front and 15mm rear....
Old Apr 21, 2009 | 06:50 PM
what sways did you go with? i did Champion H&R for both; the look greatly improved "less gap" and noticed some improvement in handling; less squat and dive, more stable @ higher speeeds. ride did not get worse maybe a hint more firm. one drawback; will likely bottom out more frequent. you have to take high bumps slow and "sideways"; you'll feel like an idiot
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
