My turbo's transformation
I went 1.1 inches lower all the way around. Ride is great. I went a bit lower initially on my 08 Cab TT after I put on the Bilstein's and the ride was too stiff for me. Went up ever so slightly and now it's perfect. Everyone has their own preference so my suggestion is to go about 1.25 inches first(per Alex) then gauge. You can always go just a tad higher if that's too low for you. Looking forward to the finished project.
You're going to have some fun that's for sure
I didn't see/notice if you added some beefier sway bars? I hope so..the cab especially could/should use them especially if you're adding the coil overs?
I'm not adding the sways at the moment since i was told that they make the car stiffer, are they necessary?
Can someone please tell me when you measure the height which points are you measuring?
Another thing, what is the difference of the ride height and the shock height?
The small springs in my coilovers are fully closed is that normal?
Sorry but i don't know much about suspensions
for height, we measured from top of tire to top part of fender. To make sure the car is even all the way around, we measured from top of wheel to the top of fender. Make sure you do this on an even surface like an alignment rack.
20mm will look exactly like Cannga's car which still looks good IMO.
https://www.6speedonline.com/forums/...uned-giac.html
For those who want to know about the GT2 bumper its not a bolt on, but there are two ways to do it.
1) Is to change all radiators, air ducts, and make it work as it does on the GT2
2) Is to change the left/right radiator ducts and remove the central duct, this is what i have done since i found no reason of doing it work the same way as GT2 does.
I have also added the Techart GT2 front lip which looks very nice and fits perfect
Just like these basically.
http://www.sharkwerks.com/products.php?pid=192
Impresive may I suggest one more thing: a lightweight battery, for instance these
http://www.voltphreaks.com/
that's too much for me. I think i'll start with dropping it 15-20mm around and we see
