997.2 turob: PDK limit vs Tuning Potential
Old Jul 4, 2009 | 03:53 PM
combo3010's Avatar
combo3010 is infamous around these parts
With the 997.2 turbo due within 60 days, some have suggested that the PDK torque limit will be around 790nm.
does it mean that the PDK can handle power Reliably up to 790nm? or that 790nm is the absolute limit for the PDK, and anything higher would destory the gearbox?
hopefully it's the latter, and some tuning on the 997.2 turbo is still possible without messing around with the gear box....
Old Jul 4, 2009 | 06:52 PM
darmawaa's Avatar
darmawaa is infamous around these partsdarmawaa is infamous around these parts
I have an Mitsubishi Evo X with Dual clutch gearbox. Standard power&tq is 280HP&422Nm. Even in stock when I dyno, there is some slip detected in power&torque graph (drop in power&tq around 5000rpm), and I can feel a little slip during driving, also once overheat warning after 1 hour hard driving (lots of WOT) on the freeway.
Later I tuned it (racing cat, reflash, intercooler, K&N) to around 360HP&530Nm, during hard highway driving the overheat comes many times during a month, and the last time it goes to limp mode, CEL appears and shift is very jerky. I have to reset the ECU and change the TC-SST Oil (Twin Clutch - Super Sport Transmission). Then I install oil transmission cooler in front of stock one. I never get any overheat or limp mode since.
Then I tuned it again (fine tuning, changing cams and exhaust, but still standard turbo), around 450HP&620Nm. It goes to limp mode (CEL) again. I plan to install 1 more oil cooler and circulating pump. Before I installed it ,I never use it in highway again, afraid the limp mode comes again. I only use it in town (you can not do a lot WOT in town due to traffic).
I bought the Evo's because it is easily modified, the motor (with garret it can be 1000HP), I think I should bought a manual tranny instead.
Have a CLS55 AMG (800Nm) never has problem, I believe it use the same 5speed auto as Porsche Tip.
Until the turbo's PDK proved to handle heavy modified, I won't buy it.
Old Jul 4, 2009 | 07:39 PM
Bigrigger's Avatar
Bigrigger has a spectacular aura aboutBigrigger has a spectacular aura about
Your not going to get 1000hp from the new 4B11 engine without MAJOR machine work, it was the old 4G63 motor that could make those numbers..
As for the DCT, I think it takes a couple of tries to get everything right, Gen 1 Nissan GTR would blow gearboxes after moderate abuse. Evo X are not blowing as often. Give them 2 more years and all the bugs will be worked out.
Old Jul 4, 2009 | 07:55 PM
darmawaa's Avatar
Yes, maybe 4B11 semi open aluminum deck can not take much abuse as 4G63 closed iron deck.
Old Jul 4, 2009 | 09:33 PM
lintc0532's Avatar
lintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond repute
hangon guys... We are in porsche 997tt forum lol...
As PDK box is so new,I doubt that tuners can easliy do any upgrade like they done to tip box..So it might be a trouble at the first 1-2 years.You gonne give tuner times to improve their parts and skills for 997tt.2.Should buy used one at least 1 year after release if you want big power.
Old Jul 4, 2009 | 09:48 PM
heavychevy's Avatar
I agree, the PDK will not be easily or inexpensively upgraded.
The PDK will be better for stock, but after that, for big hp applications, it will likely be a headache like all the rest of the dual clutch trannies.
Old Jul 4, 2009 | 09:54 PM
combo3010's Avatar
I'd be happy if the PDK can withstand Stage 2 tuning.
Old Jul 4, 2009 | 11:03 PM
yrralis1's Avatar
How many coupes did Porsche sell last month ? 15 ? Even the used 997tt's seem to sit on dealership lots .
So does PDK plus the 20 more hp with this Dfi engine impress ? Well it would have to sell more than 15 cars a month .
As for tuning potential . What tuner is going to spend time and money into reasearch and development of aftermaket enhancements when thse cars simply are not selling?
Add to this some of the problems being discussed on the 997 forum with oil consuption on Dfi engines it almost seems like PDK is the least to be concerned about .
Old Jul 5, 2009 | 12:43 AM
gmoney's Avatar
Similar arguments have been had for each generation of 911, simply put, tuners will 'find a way'.
But to the OP, who says the PDK Turbo is a few months out? It shocked the $hit out of me they changed the nav in the turbo prior to a facelift nevermind a whole new engine and transmission 3 or 4 years in.
Old Jul 5, 2009 | 01:14 AM
lintc0532's Avatar
Its true buddy..I also heard from my local dealer the PDK turbos will available to order from OCT.They said the engine would be 3.8 DFI.They don't talk xxxx as new zealand always be the last place in the world receive porsche new car delivery..
Old Jul 5, 2009 | 05:02 AM
darmawaa's Avatar
I'd wait for the 998TT, the PDK would be fully developed by then.
Old Jul 5, 2009 | 10:38 AM
OCTurbo's Avatar
OCTurbo is infamous around these parts
is that official that the 997tt is coming here with pdk and 20 more hp this summer/fall? I have only heard rumors up until now. can someone confirm this.
thanks
Old Jul 5, 2009 | 11:13 AM
SleepTight's Avatar
SleepTight is infamous around these parts
thanks
An official word would be helpful. The dealer I spoke with was very closed-lipped about the arrival of the 997.2 Turbo. No doubt because of the three 2009 997 Turbos he already had on the lot.
Old Jul 5, 2009 | 02:11 PM
KA 997TT's Avatar
KA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond repute
that's so true.
Old Jul 5, 2009 | 02:52 PM
camhabib's Avatar
camhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond repute
MY2010 Turbo's will have PDK. I already placed an order and saw verification of it with my own eyes.
PenguiN
Oct 26, 2018 07:23 AM
alevine
Nov 4, 2015 10:05 AM
Sep 1, 2015 03:16 PM
vbb
Aug 21, 2015 10:17 PM
Aug 20, 2015 12:17 PM
