Rattles in the dashboard and rear quarter panel
Old Jul 25, 2009 | 09:24 PM
msp2547's Avatar
msp2547 is infamous around these parts
I jsut picked up an 08 997 Turbo. Very clean, tracked but with only 4k miles. No aftermarket work, and OBD was clean on over-revs.
When I get the car up over 70mph on a rough surface, the car develops a rattle in the dash and in the rear quarterpanel - behind my left ear somewhere.
Has anyone had issues with rattles? Any remedies would be welcome. Planning to take it into the dealer to ahve them take a look but I htought someone out there might have been through a similar experience.
Thsi car is laoded with Carbon Fiber and I wonder if that has anything to do with it.
THANKS!
Old Jul 25, 2009 | 10:38 PM
iceefreshco's Avatar
iceefreshco is infamous around these parts
Angry
everything is covered under warranty except for rattles n' squeaks....
Old Jul 25, 2009 | 11:47 PM
Kuwait997's Avatar
Kuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to behold
THANKS!
As far as i know it's just the nature of the beast, mine does too. Rattles like you wouldn't believe, so did my F430 and my C63. So far i wasn't able to do something about it, but if you find the remedy you will definatly be my hero!!
Old Jul 26, 2009 | 07:02 AM
ONECMXLIV's Avatar
ONECMXLIV is infamous around these partsONECMXLIV is infamous around these parts
At about 2000 miles our car developed a squeak that seemed to originate from somewhere inside the passenger side of the right rear quarter panel area. It was most noticeable at low speeds on rough pavement.
According to the dealer, the lower edge of the rear window had not been fully mounted in the rubber seal and was coming in contact with metal during body flex. This was a very quick fix by the dealer.
Old Jul 26, 2009 | 02:28 PM
KA 997TT's Avatar
KA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond repute
Mine did not have as much rattles until i went with a very stiff suspension. i am running Motons and 900/600 Spring rate F/R... it is really not too bad at all even with that.
Old Jul 26, 2009 | 03:06 PM
gmoney's Avatar
Mines pretty good, I had a death rattle from the driver rear window, glass was lose...quite the fiasco with dealer fixing it 3x but now its fixed 100% after new glass was replaced and a door seal.
I typically hunt down and fix these on my own, dealers will not take as much care and simply stuff voids with that expanding foam. Even with my GMG setup the car is near silent on par with my Civic Hybrid for cabin creaks and rattles...they are only occasional and dependant on road surface. Frankly for a car of this type (performance) its shocking how quiet it is.
You have to live with some noises, not even a Rolls or Bentley is going to have zero.
There have been some issues though that plague early models i.e. some bad welds on the rear of the turbo. As for dash, just check the cover it in leather options and avoid the plastic rattles
Old Jul 27, 2009 | 08:23 AM
JZRS4's Avatar
JZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond reputeJZRS4 has a reputation beyond repute
Porsches rattle!
Every single one!
You have (2) options:
1. Turn up the radio
2. Push down with your right foot.
I favor option 2
Old Jul 27, 2009 | 09:10 AM
KA 997TT's Avatar
I take 1 and 2 here!
Old Jul 27, 2009 | 09:43 AM
Kuwait997's Avatar
1+2 = pure bliss & adrenaline rush! I'll take the combo, super sized please.
Old Jul 30, 2009 | 07:24 PM
maverick997's Avatar
maverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to all
I have a rattle around the gear shift and also the passenger rear side window. The side window didn't show up till they tried to fix the water leak in the rear side windows by tightening them.. Anyone else have small beads of water on the inside of rear side windows after washing the car? Dealer is supposed to have posed the question to Porsche but I've not heard back. They tested 3 other cars and they all had a similar issue.
Old Jul 31, 2009 | 02:30 PM
tssci's Avatar
tssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to behold
rear side window rattles...
FYI - I took care of my side rear window rattle/buzzing by pressing a length of rubber vacuum hose between the inside of the window and moulding/side inner panel - just press it in until it is not visible. It cured my annoying rattle 5K miles ago with no return after a year. To defend the marque, not a single other rattle in this 08 or the 07 TT I had before. If Porsche's did have incurable rattles as a rule, I'd find another car to drive....it would personally make me crazy. Also, not a single rattle in the 07C4S that I had in between the 07TT and 08TT.
Old Sep 22, 2009 | 06:05 PM
marcw's Avatar
marcw has much to be proud ofmarcw has much to be proud ofmarcw has much to be proud ofmarcw has much to be proud ofmarcw has much to be proud ofmarcw has much to be proud ofmarcw has much to be proud ofmarcw has much to be proud ofmarcw has much to be proud of
tssci
Just picked up a 997 GT3 with a crazy buzz / rattle on the left side rear window. Did you press the hose between the window and inner side panel at the bottom of the widow and then press the window seal back on?
Old Sep 22, 2009 | 07:12 PM
gmoney's Avatar
Left rear is a common problem but its more serious, get it looked at. There are bolts pressed into the glass, they are supposed to be secure but it looks like they have a number of them backing out as with my car. Check with dealer, I had all new glass put in to fix it after numerous attempts at dealer and self inflicted
Old Sep 22, 2009 | 08:14 PM
marcw's Avatar
going in tomorrow... I hope they don’t try and pull the “rattles aren’t covered under warranty” stunt
Jul 29, 2019 11:13 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
97GtsMonster
Nov 17, 2015 12:38 PM
gulf gt
Aug 27, 2015 10:27 AM
manishdutta
Aug 21, 2015 09:49 AM
