Pagid brake pads
Old Jul 30, 2009 | 08:53 AM
darmawaa's Avatar
darmawaa is infamous around these partsdarmawaa is infamous around these parts
Pagid brake pads
Is it better thank stock?
Anybody experienced which color most suitable for high speed free way driving (60-120mph) ? Should I trued the disc?
Blue
Well balanced all-round compound with high level of friction in cold and hot condition, extremely fade resistant. Best for slalom, rally, hill climb and short road tracks.
Orange
Higher friction coefficient than Blue compound with even less fade after extreme braking. Best for rally, slalom and all tracks.
Yellow The successful pad for long distance races! Outstanding low wear rate and durable performance even under extreme brake usage. Best for long distance racing.
Black High-performance compound on ceramic basis, gives "instant"bite and nevertheless can be handled simply and provides acceptable wear rates on discs. Circuit races.
Old Jul 30, 2009 | 10:15 AM
landjet's Avatar
All the racing pads will squeal compared to a street pads. You can learn to modulate the pedal to eliminate 98% of the squeal. Blacks will stop you the fastest but will wear the fastest. Yellows will last the longest. Orange will squeal the loudest. I use yellows front, blacks rear, to help improve front to rear brake bias on my 996TT, but I mostly track my car.
Old Jul 30, 2009 | 10:32 AM
WTT997's Avatar
WTT997 is infamous around these parts
I have Pagid Yellow for track usage, Black will wear the disc faster. Both are very good for high speed hard braking.. For street use, i suggest you upgrade to braided hose will do.
Old Jul 30, 2009 | 10:37 AM
XPGT2's Avatar
XPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to behold
Unless you are going to the track I would stay with the Stock Pads. Good cold bite, no squeal,and fade should not be an issue.
Peter
Feelgood MD
Mar 24, 2016 09:35 AM
XLR82XS
Oct 5, 2015 07:02 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
