EVOMS Latest 997TT Project: 9000 RPM’s, 4.0L and 1100 HP. Details Inside
Old Oct 3, 2009 | 01:49 PM
  #91
wat_it_IS's Avatar
wat_it_IS is infamous around these parts
Wow, nice quality parts and very much anticipated build of the year!
Old Oct 3, 2009 | 05:09 PM
  #92
ChasenIS's Avatar
ChasenIS is infamous around these parts
So now were beyond the 1000hp line. Great job!
Old Oct 3, 2009 | 07:26 PM
  #93
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
Thank you!
Thanks! We are already well beyond the 1000 hp line with our 3.8L. This engine will be past the 1100 AWHP line
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
Old Oct 3, 2009 | 07:34 PM
  #94
sharkster's Avatar
Never stops eh? :P N2it are you watching this mate?:P
Old Oct 3, 2009 | 07:38 PM
  #95
Originally Posted by robmd99
I appreciate your response. Concerning my build, the limiting factor is not my boost but the amount of spark that I am can produce.
Robert
Yes, this is a problem with the 996/997TT engines. If you run too hot of a spark plug, you can fire the mixture but the cylinder temperatures go through the roof. With a better firing coil, you can run a colder plug which lowers cylinder temperatures. It is a tough game.
<O</O
We spent over a year developing our coil packs to operate properly under these extreme conditions. We have not tested our coils on a 500 HP car because this would have no impact on how they will perform on 1000 + HP cars. We had a need for higher spark energy on Joes engine and began our product development for the criteria based around his engine. A coil pack tested on a 500 HP engine yielding favorable results does not necessarily translate into success for a 1000 HP car. It seems that maybe you are doing the high HP testing for bbi on these. <O</O
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Old Oct 3, 2009 | 07:40 PM
  #96
Are you kidding? It NEVER ends my friend. You and I both know that. When are you going to build a 4.1L eh?
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Old Oct 3, 2009 | 07:43 PM
  #97
sharkster's Avatar
No it doesn't... We finished building the motor on a 997TT EVT700 car... now got two GT3's to tear apart and make 3.9. 4.1 is on ze cards. We didn't even finish the 3.9 and we already promised, remember
PS When does the weekend start?
Old Oct 3, 2009 | 07:46 PM
  #98
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Thank God it never ends... it would be extremely boring if there was a designated destination instead of a journey for more horsepower.
Robert
Old Oct 3, 2009 | 07:49 PM
  #99
sharkster's Avatar
Robert
In that case.... you got the new head studs? The coils? Axles? Hmm anything else?
Old Oct 3, 2009 | 08:00 PM
  #100
robmd99's Avatar
Just waiting for you Alex to bring me the goods
Robert
Old Oct 5, 2009 | 02:33 PM
  #101
We just finished the heads. See pictures below. We CNC ported the intake and exhaust ports just like the heads on Joetwint's 1100 HP 996TT engine. We also increased the valve size on both the intake and exhaust. The big difference with these heads is the valve train. We are using Ferrea titanium valves, retainers and keepers as well as their racing springs. We shaved 52% off of the weight of the entire valve train with this setup. This will help the engine rev quicker and be much safer especially at 10K RPM's <?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 class=inlineimg title="Stick Out Tongue" src="https://www.6speedonline.com/forums/images/smilies/tongue.gif" alt="" border="0" smilieid="6" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" v:shapetype o<>We are starting to do the final mock assembly tonight and should begin the final assembly of the bottom end if all goes well. We are machining a new solid lifter conversion as we speak which will eliminate any of the variable lifter adjustment. Once these are complete, we can then complete the bottom end. More updates shortly
</v:shapetype>
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Old Oct 6, 2009 | 09:12 PM
  #102
Today we did our mock up engine assembly to check the valve clearance. We clayed the piston to see the interference between the valves and the pistons with our camshaft profile. We have to machine some larger valve relief’s in the pistons in order to make enough clearance for the high lift and longer duration camshaft that we developed for this engine. We will machine the pistons in the AM and hopefully we will begin final assembly in the afternoon tomorrow.
<O
Here are some pictures of the knife edged crankshaft mounted in the case. We also disassembled one of the heads to show the extensive port work that we perform on the heads to make them flow enough volume for this type of engine. Enjoy!<O
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Old Oct 6, 2009 | 09:20 PM
  #103
robmd99's Avatar
Looking good
Robert
Old Oct 6, 2009 | 09:32 PM
  #104
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Top shelf stuff as always!Great Job guys!
Old Oct 6, 2009 | 09:35 PM
  #105
Thanks Joe. Your heads look just like these
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
