softronic flash - choppy and backfiring - plugs?
Old Dec 9, 2009 | 05:38 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
doesn't sound like the plugs to me. Keep us posted. thanks.
Old Dec 9, 2009 | 07:03 PM
Softronic's Avatar
Veteran: Marine Corps
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
Hello All,
I just found this post and PM at the same time. The fastest way to contact Softronic would be by an email to us or phone call. An email is OK however you have to give us a reasonable amount of time to answer. Sending me a PM on this site is by the luck of the draw as I do not log on much. I find this much easier than a forum that does not have the specifics or capability to check or change the file.
The car was just flashed last night after hours. Flash the car back to stock and I will double check the file first before the plugs get done. The original file was sent to you today. I do not send them immediately as the files are getting larger and a day or so should not be an issue. Yes with higher boost and unknown prior service history with fuel quality the plugs could be an issue.
Best Regards,
Scott Slauson
Old Dec 9, 2009 | 07:20 PM
ed997tt's Avatar
ed997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to behold
Thx Scott - you were the first person I contacted and next time I will email or call rather than send a PM. I posted to get some input and to see if others had such problems and had solutions. I hope you did not take this as bashing or a customer support issue because that is not the case nor was it my intent in any way. regards, ed.
Originally Posted by Softronic
Hello All,
Best Regards,
Scott Slauson
Old Dec 9, 2009 | 11:49 PM
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
Swap the plugs, It is Not going to hurt, Only Hurt your motor when its miss Firing. Stock or Not always have a good ignition system. My car has 30k and I swapped the plugs myself. Remove bumper, intercoolers, and Wastegate(VNT servos/linkage) $600 is alot to pay the dealer to swap plugs.
Good Luck
Old Dec 10, 2009 | 07:28 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I would try to flash back to stock first as others have said
Good Luck
Dude you are a masochist. It looks like a PITA even with the engine out!
Old Dec 10, 2009 | 01:05 PM
vividracing's Avatar
Bet you a beer it is the plugs!
Old Dec 10, 2009 | 02:56 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
I am almost sure it is plugs...I changed mine without removing bumper and intercoolers...i just removed turbo inlet pipes to empty some space...it took me 3hours however...
Old Dec 10, 2009 | 03:58 PM
gmoney's Avatar
plugs on 997TT I hear its more of a pain
Old Dec 10, 2009 | 08:21 PM
Verdict?
Old Dec 11, 2009 | 08:41 AM
ed997tt's Avatar
Guys - thanks for responses, suggestions and help. It is what makes this such a great forum. It was the plugs. Replaced them yesterday with denso IK22's and car runs great. Looks like I owe Mr. Mermelstein a beer.
Old Dec 11, 2009 | 09:06 AM
So how does the car feel?
Old Dec 11, 2009 | 09:29 AM
ed997tt's Avatar
power increase is very noticeable, lag seems diminished a bit and car really pulls. Mine is a DD so normal day to day driveability is also very important and car feels smoother there as well. absolutely recommend.
Old Dec 11, 2009 | 10:31 AM
I believe we can share a beer with Dan...i wrote two times it was plugs...i had same issues one month ago...
Old Dec 11, 2009 | 10:34 AM
bbywu's Avatar
Congrat's on a quick and prompt fix to your problems.
- bob
Old Dec 11, 2009 | 02:58 PM
ed997tt's Avatar
Thx Bob
- bob
