Dropped off modded tt at dealer today ,fingers xx
Old Dec 9, 2009 | 04:43 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
They didn't ask & i didn't tell,as far as mods ,i've been to this dealer before but not since any mods.Couple of warranty issues a coolant leak up by the radiator which was already replaced in March under warranty & outside temp gauge gone wild sometimes reading 150 degree's.Clearly they will see my exhaust ,headers ,y-pipe , plenum & the fact that it's lowered they said they will run a scan to check for any fault codes so not sure about the proto flash.
Old Dec 9, 2009 | 04:59 PM
gmoney's Avatar
you should be A ok with that 'to do' list for the dealer. They would be hard pressed to fault the mods.
Old Dec 9, 2009 | 07:49 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Which dealership did you go to?
Old Dec 9, 2009 | 08:30 PM
TD997TT's Avatar
TD997TT is infamous around these parts
I had the outside temp gauge gone wild too. Temp reading seemed to go higher the faster I drove. Turned out it a piece of the bracket that holds the sensor in place snapped off so the sensor was too close to the front radiator. My shop (non dealer) made a simple repair, and it's working fine again.
Old Dec 9, 2009 | 09:44 PM
yrralis1's Avatar
If you dropped it off in the afternoon and they didn't call you by the end of the day after starting it up --that's a pretty good start .
Old Dec 9, 2009 | 09:54 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
any check engine lights on...
Old Dec 9, 2009 | 11:10 PM
twturbo's Avatar
Dropped it off at Walters Porsche this morning no calls yet,cell light for low coolant level which is what caught my eye ,when i got home i had pink radiator fluid all over the pass side of car from front to back & all over my HRE's,hopefully it's not corrosive it seemed to clean off well.
Old Dec 9, 2009 | 11:53 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
You should be ok. I wouldn't worry too much.
Old Dec 11, 2009 | 06:43 PM
twturbo's Avatar
Picked up my car today from Walters Porsche with no problem & no charge ,ended up being a bad radiator hose & outside temp sensor replacement ,they even tightened & adjusted my aftermarket exhaust tips for no chargeThey said they ran a scan on it & took it for a test drive.
Old Dec 11, 2009 | 09:26 PM
Tacet-Conundrum's Avatar
Tacet-Conundrum is infamous around these partsTacet-Conundrum is infamous around these partsTacet-Conundrum is infamous around these partsTacet-Conundrum is infamous around these partsTacet-Conundrum is infamous around these parts
Modded TT and you don't think the mechanics won't see what the beast can do?
Old Dec 11, 2009 | 09:28 PM
N2it's Avatar
N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !
Hope they were easy on the test drive.
Old Dec 12, 2009 | 12:35 AM
2008911tt's Avatar
2008911tt is infamous around these parts
I have Fabspeed headers, sport cats, mufflers and exhaust tips as well as intake. I have taken my car in for routine service at the dealer as well as a warranty item. The only comment I heard from the dealer was "it sounds good." You should be okay.
Old Dec 12, 2009 | 01:41 PM
RaminGTI20's Avatar
RaminGTI20 is a jewel in the roughRaminGTI20 is a jewel in the roughRaminGTI20 is a jewel in the roughRaminGTI20 is a jewel in the rough
either way, they have to prove the aftermarket parts are the cause of any problems your car has....you will be fine
orbelo
Aug 30, 2015 12:26 PM
tommyboy214
Aug 26, 2015 10:49 AM
pwdrhound
Aug 23, 2015 07:36 PM
HolmaN
Aug 19, 2015 07:32 PM
