IPD or Agency Power
Old Dec 31, 2009 | 08:30 AM
993rscs's Avatar
993rscs is infamous around these parts
IPD or Agency Power
Hello everyone, I'm new to the forum, but I've been searching around here for quite a while. Anyways, I have a question hopefully some of you guys can answer.
I have a 2007 Porsche Turbo and I want to do a plenum/tb upgrade. I'm going to be doing larger turbos, intercoolers, the whole works in a couple of months as well. As for the plenum/tb, I've heard great things about the Agency Power setup as well as the IPD. IPD claims around 28+ hp and 30+ torque on a stock turbo, and agency power is claming 46+ hp and 60+ torque on a turbo with turbos, intercoolers, flash tune, etc. This is where I'm kind of torn between which kit. The IPD is a bit more expensive but it seems that a lot of Porsche owners who do this upgrade go for the IPD.
Also, IPD has a competition throttle body that is 82mm, compared to the 78mm from Agency, but if I put a larger diameter TB, will this kill my low end and cause some turbo lag? Or will I be fine with it until I do all the other upgrades?
If anyone can give me any input to help me with my decision I would appreciate it. Thank you!
Old Dec 31, 2009 | 08:55 AM
997FL's Avatar
997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !
We currently have both the 82mm competition and the 75mm regular version IPD plenums in stock. If you are planning on keeping your stock turbos I would use the 75mm IPD plenum and call it aday. If you plan on upgrading your Turbos in the near future, I would recommend going with the 82mm Competition version and combining it with the GT3 cup car throttle body and EVOMSit tune for the following upgrade. This will certainly enable you to squeeze out a few more ponies =) We have done both and the customers have always been stoked with the gains.
Pm sent
Old Dec 31, 2009 | 08:58 AM
vividracing's Avatar
Our Agency Power unit is newer, power proven, and half the cost. Plus I offer a 100% money back guarantee. No extra tuning required. Bolt on and go!
Old Dec 31, 2009 | 09:07 AM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
Originally Posted by vividracing
[removed comment about other vendor's products]Plus I offer a 100% money back guarantee. No extra tuning required. Bolt on and go!
sounds good!
Dan could you post some pictures? Is plenum is T or Y shape?
All the best in New Year !!!!!!!!
Old Dec 31, 2009 | 09:11 AM
Sure thing, you can also view the link here - http://www.vividracing.com/catalog/a...9-p-79632.html
Since the engine works off pulses, once through the throttle body, it really does not matter if it is a Y or a T shape. Everything leading up to your throttle body and the diameter of the throttle body itself is your restriction.
Old Dec 31, 2009 | 09:24 AM
ok. need explenation.
bigger is throttle and plenum?
what is the size difference compare to the stock?
thanks !
Old Dec 31, 2009 | 09:29 AM
Click the product link in my post above, most explained there. But just so you know, the throttle body is bigger diameter then stock with a bigger inlet to the Tpipe. The sides of the Tpipe must be kept the same diameter of stock to fit to the factory intake manifolds. Our plenum kit is actually the same overall diameter from throttle body to sides.
Get one at my special price and you will not be sorry
Old Dec 31, 2009 | 09:40 AM
ok, now I understand sounds good a specialy in combination with my bigger pipes between coolers and throtle.
Will call my ecu guy at beggining of the week and If I force him to change it I will takie it.
Old Dec 31, 2009 | 09:43 AM
Originally Posted by bbywu
Dan, how do you know this to be true?
Guys, but here we are talk only about 82mm ipd or in combination with 82mm throttle? I think 997 gt3 is the biggest one?
Old Dec 31, 2009 | 10:14 AM
The 82mm is big and you will lose alot of low end power unless you have an equal Ypipe in diameter with no restrictions through the intercooler to the turbo.
Old Dec 31, 2009 | 10:22 AM
As I remember I have 57mm cooler intake, 60mm cooler outlet and Y pipe is 65mm and further stock throttle....
Old Dec 31, 2009 | 10:59 AM
some answers just disipired.....
but I think Dan is right that bigger throttle need ecu tuning, because it's much larger...
I remember my ex gt2 was running with big throttle from cayenne or gt3.
during driving there was shaking sometimes, so I drive with my ecu guy and he was changing some parametrs real time and after few minutes there was no shaking so I asked what it was? he said ecu didn't noticed that we are running with bigger throttle
Old Dec 31, 2009 | 11:37 AM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
Not trying to step on anyones toes but it's hard for me to believe that a T plenum will flow equally with the y plenum. We can use h2o for example and pore it down the T pipe then do the same with the Y pipe. The water would eventually be stopped when it hits the dead end of a T. As more water is being pored into the T it will eventually start moving again. IT'S COMMON SENSE . If the theory works why would porsche make a y pipe instead of a T pipe?? just look at your y pipe where it joins together before the throttle body. a T would be be easier to joint saving time n $$$.I think the Y shape would explain itself.
Old Dec 31, 2009 | 11:58 AM
The engine works off pulses, so once it is behind the throttle body, does not matter if it is a T or a Y. Does not matter to me really, we have our design with proven results, and others have theirs.
Old Dec 31, 2009 | 01:12 PM
997FL's Avatar
Here are some dyno results from the IPD 75mm Plenum: 3 different cases are pictured below.
