Official 6speedonline 997TT performance list: mods and result
Old Jan 7, 2010 | 11:56 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
Hi everyone,
I'm in my way to upgrade my 997TT to 700/750 kit. As part of the intensive search I have done, I found a lot of great feedback from tuners and owners, so I thought about set spread sheet that can be updated by everyone to compare different cars with different kits to help everyone to make the right decision when it comes to upgrade the 997TT engine.
Before we start I would like to clarify or highlight some points:
- I'm not professional and far from being professional. I'm regular person with engineering background ( help me to understand a lot of things ) who loves his car so much , so I might have wrong info and everyone is always welcome to correct me.
- expensive kit doesn't not mean fast car and visa versa. High dyno HP and torque numbers don't mean fast 1/4mile and 60-130 as a lot of variables effect the dyno result.
so there are a lot of reasons that makes someone goes to one kit over the other: price, speed, reliability, warranty, location, relation, customer service ... etc etc. This thread with the updated sheet will help me and everyone to make the right decision, and always remember THERE IS NO ABSOLUTE BEST.
The compression is going to be between cars as fallows:
tuner:
kit name:
Turbo:
ECU:
Intercoolers:
exhaust:
air intake:
clutch:
extra parts:
dyno resault:
Max Power=.......- max torque=.......ft-lbs with PUMP fuel at.....bar -Temp=.....
Max Power=.......- max torque=.......ft-lbs with RACE fuel at.....bar -Temp=.....
0-60mph:....sec
0-100mph:....sec
60-130mph:....sec
1/4 mile:....sec @ .... mph
standing mile:....sec@.....mph
transmission: 6spd - tip - PDK
tires and wheels:
extra info about the kit and car:
If there is anything I should add to the list that I forgot please let me know.
click here to see sample of the sheet I'm working on. Most of the information were gathered from the posts by 6speed members. nothing out of the 6speed community.
There is a lot more info's that I have saved in word file about same cars with different set up that were changed over the time or some issues needed to be fixed and how, but I listed the last result or the best. Also I have a lot of technical info from tuners websites and posts about their kits. ( ALL AVAILABLE IF NEEDED)
- Abdullah
Old Jan 7, 2010 | 11:57 PM
TPC-Racing
KIT:
775Blitzkrieg
Turbo:
modified turbo VTG turbochargers. 2.0mm larger compressor inducer than the stock GT2 and a 1.5mm larger exducer. VNT turbines
I have read somewhere that they use VNT turbines as well I’m not sure if those are different than the factory ones used on the red car.
Intercooler:
TPCRacing 775Blitzkrieg Intercoolers, with a whopping 127mm(5") core
ECU:
N/I
Exhaust:
BLITZKRIEG 76mm EUROPIPE Exhaust custom built by EUROPIPE for the 775 kit.
Clutch:
N/I
Extra:
1.0bar @ normal and 1.2bar @ sport mode for the dyno numbers
Performance:
Dyno:
Max Power=652.03 - max torque=548.40ft-lbs with fuel pump 93 at
1.05 bar
Max Power=673.08 - max torque=605.53ft-lbs with fuel pump 93 at
1.25 bar (temp = 84.04 F, baro pressure = 29.54 in-Hg, humidity = 26%)
Dynojet
0-60: N/I
60-130: 6.8 with a shift. It was measured during ¼ mile run
1/4mile: 10.650 sec at 135.21 MPH
ran the car with less load and it dynoed previous to this run @ 628 whp... this is a bit less than the 675 the car is delivered as the 775 package.
Extra info from TPC:
We have been compared to the protomotive ICs... they are very different ICs as ours are hybrid core... both are 4.5" though. Mike and Todd are very good friends and share a lot of the same philosophy in regard to tuning but I can assure you that our 4.5" core is exclusive to TPC. Protomotive is up there with the best of them. Ic = intercoolers
10.6 in the quarter @ 135 with wheel spin on the low HP setting(623~whp)... we believe it is good for a near 10.0 on pump but we dont have the time or a cage in the car to run it. we have never tried to get a 60-130 time.
The turbos are factory 997TT turbos rebuilt to our specifications. When purchasing a 775B kit your turbos are required to be sent back as cores
https://www.6speedonline.com/forums/...997tt-yet.html
Users with this kit:
N/I
__________________________________________________ __________________________________________________
tuner: SWITZER
kit name: L4 700/750 PKG
Turbo: VTG
ECU: nii
Intercoolers: SPI MONSTER IC’s 6''
We have found that the 6" is a no-bull high performer for both street and track, has less than a pound per-square-inch of pressure drop across the core which is very important and shows just how efficient these are.
When you are on the track, with ambient temps easily going above 100*, the more surface area you have to exchange the temp, the easier it is for the IC to lower the temps to that level, making intake air temperatures will be much more stable than a smaller core that will heat up very quickly and have a hard time bringing the IAT down to near ambient temps.
exhaust: competition style Full exhaust by SPI
air intake: Y-pipe by SPI
clutch: SPI HD clutch system for 6speed 997TT
extra parts: n/i
dyno resault:
0-60mph: 10.666@132.65MPH
0-100mph:....sec
60-130mph:....sec
tires and wheels:
https://www.6speedonline.com/forums/...g-gallery.html
users with the kit:
1) Webtool1 :
2) whiteknight;
3) GT RUS:
4)vboxking
5)evoviiiyou
tuner: EVOMS
kit name: EVT700
Turbo: VTG
ECU: EVOMSit
Intercoolers: EVOMS 99TT clubsport IC’s 25% larger core than OEM intercoolers
exhaust: 70mm exhaust system with 200 cell catalysts
41.5mm primary tube diameter headers.
air intake: n/i
clutch: EVOMS 997TT stage 3 clutch supports sustained torque levels beyond 740ft/lbs ( factory 640 ft/lbs).
extra parts: EVOMS 997TT boost recirculation valves
dyno resault:
Max Power= 703HP (607.673) - max torque= 690 (609.329) ft-lbs with fuel pump 93 at
Bar (n/i)
Max Power= 730 - max torque= 728 ft-lbs with 103+ octane race fuel at (n/i)
AWD 17.5% correction factor as tested on the EVOMS mustange 500-SE AWD chassis dyno.
0-60mph:2.9sec
0-100mph:6.8sec
60-130mph:....sec
1/4 mile: 10.81@133.5MPH fastest 10.79@134
standing mile: 190MPH
transmission: n/i
tires and wheels: n/i
http://www.evoms.com/evo/Pages/EVT700INFO.asp
1) 911JT
2) elow
Tuner: AWE-tuning
Kit:
750R -
Turbo:
A.W.E. Tuning VTG Turbos, developed in a joint venture between A.W.E. Tuning and BorgWarner, who is the manufacturer of the OEM 997TT turbos.
ECU:
G.I.A.C. Software Programs
Intercooler:
37% larger than OEM (422 cubic inches vs 308 cubic inches) they also drop air intake temperatures by 55 degrees Fahrenheit and improve pressure drop resistance through the core by 1 psi.
6-ply silicone hoses with gentle curves to prevent bursting under pressure with clamps
Exhaust:
German made 200 cell high flow catalytic. The rest of the system made by AWE.
Extra:
n/i
Clutch:
Stage2 Clutch Kit - hold over 544 lb/ft torque while maintaining stock-like pedal effort. ( included in the kit )
The Stage 3 Clutch kit is conservatively rated to hold over 644 lb/ft torque. Pedal feel is slightly stiffer than Stage 2 with a higher release point. ( I think it’s optional )
Performance:
Dyno:
Max Power= 600HP - max torque= 543 ft-lbs with fuel pump 93 at 1.1bar
Max Power= 630HP - max torque= 574 ft-lbs with fuel pump 104 at - 1.2 bar.
Mustang dyno – bar reading not in the website Post #53 also there is a sheet showing 22.3 psi ( 1.537 bar ) for the 700S kit
Numbers:
0-60: n/i
0-100: n/i
60-130: n/i
1/4mile: 11.2 at 128 mph in early testing on pump gas.
1 mile : n/i
Extra info :
ability to switch between software programs on the fly
1) Botox
2) quik 911
3) onecmxliv:
self install:
https://www.6speedonline.com/forums/...-pictures.html
4) jnixon:
11.5 129mph 1/4mile on the race gas setting of the AWE 700/750. I am not speed shifting but this has been my best trap speed and et time. I did this with the sport button off and the traction control on.
5) Eclou:
0-60: 4.2 ( in Texas miles 10mph headwind)
0-100:
60-130: 0-130mph of 6.97s and 7.00 58F, no wind, concrete road (not a prepared track)
1/4mile:
1 mile : 185.8 with a weak launch (left PSM on). 6-10mph slower than the previous event from the headwinds
6spd manual
https://www.6speedonline.com/forums/...it-review.html
VIVIDRACING
Kit:
VR750
Turbo:
Modified factory turbo’s. ach turbo is disassembled and rebuilt with a larger turbo wheel that flows almost 40cfm more then the stock units.
ECU:
Softronic
Intercooler:
Agency Power High Flow Intercoolers *
Exhaust:
Agency power full exhaust
Extra:
Agency Power Carbon Fiber Cold Air Intake
Post recirculation valves
Clutch:
Clutch Masters Stage 3. designed to hold up to 800 horsepower with an OEM feel.
Performance:
Dyno:
Max Power= - max torque= ft-lbs with fuel pump at
bar
Bar
The VR700 turbo kit put out a very strong 616awhp and 632ft/lbs of torque with the Mustang Dyno correction factor. Our test vehicle was a 2007 Porsche 997 Turbo Tiptronic. The car reached its final number using VP109 octane unleaded fuel at 1.3bar of boost. As tested on pump gas, the car still made an impressive 557awhp and 600ft/lbs of torque. With an ambient temperature of 92F in our dyno room
Numbers:
NO info
0-60:
0-100:
60-130:
1/4mile:
1 mile :
Extra info :
http://www.vividracing.com/catalog/v...7-p-65514.html
1) Caleb_StuntMan:
gumball3000 car 4000 miles with no problems - tiptronic
2) KA 997TT:
now has EVOMS EVT700 but here is what he got with the kit:
the car down to the Mustang AWD Dyno to give it a whirl. The ambient temp was 90F and humid since we just had a rain storm. Pump gas 93 octane we ran it 3 times and came out with 510awhp and 580ft/lbs of torque. Strap that to a Dyno Jet, you are talking 550awhp. Put 109 unleaded gas in it, you are pushing close to 600 wheel horsepower. Oh yeah, and drop the air temp to 70F and the turbos love you again. In the end, we did the job, the customer only wanted about 650 crank and we have accomplished that mark. Enjoy the pics and video.
PROTOMOTIVE
Kit:
Turbo: Upgraded VGT
ECU:Protomotive by todd
Intercooler: 5’’
Exhaust:n/i
Extra:n/i
Clutch: lwfw/sachs motorsport clutch upgrade
users with the kit:
1) keithta
Search under his username a lot of good info although he has bigger kit
https://www.6speedonline.com/forums/...-mile-run.html
2)997john:
3)red 9:
4) aisxos :
I run modded turbos, big intercoolers Tiptronic ECU, DME, headers for 2 years time now.. I have done more than 40.000km with this setup full throtle.. Everything by protomotive... MY CAR is a bullet!!! Great results with no problems at all...
my car 997 turbo tiptronic which is stock Ecu but has cargraphic's sport exhaust and headers did today (After 14000km) 0-100 in 3.7 and 100-200km/h in 7.9 so 0-200 in 11.6 !!! (Performance box times)
5)treynor:
Car: 2007 997 Turbo 6-speed
Mods: Protomotive ECU & upgraded VTG turbos, EVO headers & stage II clutch, Miltek exhaust, HRE C21 wheels
Stock tires.
Fuel: 94 octane unleaded (1/3 100 octane Sunoco unleaded, 2/3 91 octane CA pump swill)
Temps: 85F
"sport mode": 11.4, 11.5, 11.5, 11.6 at 123 - 124 MPH
"non-sport mode": 11.9, 11.9 @ 120 MPH
Old Jan 8, 2010 | 03:23 AM
DINpower's Avatar
DINpower is a jewel in the roughDINpower is a jewel in the roughDINpower is a jewel in the roughDINpower is a jewel in the rough
Originally Posted by cayenne_ksa
Hi everyone,
You sure ?
tuner: Cargraphic/RS Tuning
kit name: Stage 3 + Carrillo
Turbo: VTG
ECU: standard Motronic
Intercoolers: Secan
exhaust: Cargraphic
air intake: Cargraphic carbon
extra parts: CG headers, 100 cell race HJS cats
dyno resault: engine dyno: 624PS, 900NM DIN
Max Power=..624PS- max torque=.662ft-lbs with 100RON Shell V Power PUMP fuel at.DIN....bar -Temp=.DIN....
Max Power=.N/A.- max torque=..N/A..ft-lbs with RACE fuel at.....bar -Temp=.....
0-60mph: est.2.9s...sec 0-100kph: 3.0s
0-100mph:est.6.8s...sec 0-200kph: 9.1s
60-130mph:est.7s...sec 0-300kph: 23.8s
standing mile:est .30s..sec.190....mph
transmission: 6spd 890NM Sachs clutch
tires and wheels:9X19 12X19 Dunlop Maxx
extra info about the kit and car: Wears full GT2 bodywork so extra drag over 200kph compared to 997tt, engine is built including Carrillo rods, oh and test weight of 1519kg/3350lbs (full of fuel but no passengers) probably helped a bit
Old Jan 8, 2010 | 08:32 AM
mickym0u53's Avatar
mickym0u53 is a splendid one to beholdmickym0u53 is a splendid one to beholdmickym0u53 is a splendid one to beholdmickym0u53 is a splendid one to beholdmickym0u53 is a splendid one to beholdmickym0u53 is a splendid one to beholdmickym0u53 is a splendid one to beholdmickym0u53 is a splendid one to behold
Thanks for all the time and effort put out to oragnize this list for other members!
Old Jan 8, 2010 | 10:09 AM
Originally Posted by DINpower
You sure ?
Turbo: VTG
Intercoolers: Secan
exhaust: Cargraphic
Yes, price wise as VIVID and PROTOMOTIVE a lot cheaper, but I do love cargraphic a lot and love the work they put on their products.
Old Jan 9, 2010 | 03:28 AM
CTT-QTR's Avatar
CTT-QTR is a glorious beacon of lightCTT-QTR is a glorious beacon of lightCTT-QTR is a glorious beacon of lightCTT-QTR is a glorious beacon of lightCTT-QTR is a glorious beacon of lightCTT-QTR is a glorious beacon of light
Thanks 3bdullah I'm sure this post will help many members thinking of getting any of those kits .
Old Jan 16, 2010 | 01:19 PM
THEMASH's Avatar
THEMASH is infamous around these parts
great info, thanks
Old Jan 20, 2010 | 07:04 AM
TPCRacing's Avatar
TPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond repute
Thanks for adding us... Please note that our 775 car uses Sachs Motorsport clutch available through us... The only thing that we found that would hold our level of power without going to a multipack(which isnt streetable). The 775 car also was running our old 4.5" intercoolers when that time was run... Our 5" coolers have not been run yet... Currently 4 other 6speeders with teh 775 kit that just havent chimed in yet, i suppose.
Old Jan 27, 2010 | 08:25 AM
vividracing's Avatar
I appreciate being in the same classification as TPC, Proto, EVO, Switzer. I have 2 very fast cars in Kuwait and many more customers.
Abdullah please add my correct kit and delete that other info - http://www.vividracing.com/catalog/v...9-p-80007.html
Last edited by bbywu; Jan 28, 2010 at 12:26 PM. Reason: removed response to other member's flame
Old Jan 27, 2010 | 09:09 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
cayenne_ksa,
I think most will agree that each of the kits and manufacturers you've mentioned above make a good product. Although I have my personal preferences (EVOMS), I will say this. As an end user you need to consider not only the hardware and performance of the kit, but also give a lot of consideration to reliability and after-purchase support.
Sure, there are many folks out there who can make great power and build a super fast car, but the key question is how well do these cars run a month, three months, a year, two years, down the road? I can honestly say that the EVT750 and EVT800 kits we've installed are all still running flawlessly and between EVOMS and their fantastic network of dealers I don't think you'll find a better, more proven, and reliable solution.
Botox's Avatar
Botox has a spectacular aura aboutBotox has a spectacular aura aboutBotox has a spectacular aura about
With the AWE 700S/750R kit also has the larger throttle body/plenum combo as well.
Old Jan 27, 2010 | 11:31 AM
I'm working on the sheet and will be updated with more info soon
Dan: The kit above is the modified VTG kit as i was focusing mainly on this level but I will add you monster kit ;-)
Old Jan 27, 2010 | 09:53 PM
UPDATED vivid 825, cargraphic and some other members
Old Jan 30, 2010 | 09:47 AM
evoviiiyou's Avatar
evoviiiyou is a splendid one to beholdevoviiiyou is a splendid one to beholdevoviiiyou is a splendid one to beholdevoviiiyou is a splendid one to beholdevoviiiyou is a splendid one to beholdevoviiiyou is a splendid one to beholdevoviiiyou is a splendid one to behold
Hi there Abdullah. Above you have me listed under the Switzer L4 700/750...which I do not have. Just wanting your list to be a accurate as possible. you have received my updated info. Again great job compiling this info.
Old Jan 30, 2010 | 02:03 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
When i see pictures like this it just makes my day
