Sat radio question...
Old Feb 5, 2010 | 09:28 PM
TT Surgeon's Avatar
I hooked it into the fusebox with a spade clamp, didn't need that other part afterall. The sound is horrible though, a constant whirring that goes up/down with the engine RPMs and it sounds muffled, almost like an AM radio. I have it plugged into the RCA ports in the denison aux. Any ideas?
c
Old Feb 6, 2010 | 06:54 AM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Where is the Dension grounded?
Use a ground loop isolator on RCA input of GW500 unit to eliminate problem. Happens sometimes...
Old Feb 6, 2010 | 07:14 AM
TT Surgeon's Avatar
Not sure where the denison is grounded, don't recall a sep ground wire on it. Can you post a pic of what you're talking about with the rca input.
tia
c
Old Feb 6, 2010 | 09:08 AM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
You can get the loop isolator from radio shack.
Old Feb 6, 2010 | 07:19 PM
TT Surgeon's Avatar
The loop isolator worked like a champ, thanks guys!
Old Feb 6, 2010 | 07:59 PM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
I mounted mine in the front bumper. It is out of site and works perfect from there.
vpr80
Mar 6, 2021 12:11 PM
7thsign
Dec 12, 2015 07:43 PM
Mz3bo
Oct 1, 2015 06:32 PM
Collinsjd
Sep 29, 2015 09:38 AM
