997TT tip upgrade
Old Apr 13, 2010 | 09:00 AM
  #46
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Ok regarding the TC, this is not an upgrade in my opinion, it is actually hard on the gears, it is something like holding the clutch on the manual gear and rise the RPM and then left the clutch, please chime on this if i'm wrong.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
all the Performance shops which upgrading the tranny they change the clutches and add more discs and modified the valve body.<o></o>
<o></o>
So don't expect much from changing the TC only, sooner or later you need to do something with the clutches.<o></o>
Old Apr 13, 2010 | 09:47 AM
  #47
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Originally Posted by 997John
Ok regarding the TC, this is not an upgrade in my opinion, it is actually hard on the gears, it is something like holding the clutch on the manual gear and rise the RPM and then left the clutch, please chime on this if i'm wrong.fficeffice" /><o>></o>>
all the Performance shops which upgrading the tranny they change the clutches and add more discs and modified the valve body.<o>></o>>
<o>></o>>
So don't expect much from changing the TC only, sooner or later you need to do something with the clutches.<o>></o>>
So you are saying that TC should not be upgraded? Or add discs/change valve body and then do the TC?
I have never heard of anyone braking tha TC
Old Apr 13, 2010 | 10:17 AM
  #48
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
you should check your TC. If there is nothing wrong with it, leave it alone. It's not the part that slips. You must add extra discs.
Old Apr 13, 2010 | 10:21 AM
  #49
997John's Avatar
Yes bro if i want to upgrade my trany i'll start with the clutches and the valve body and might go with oil cooler and even i'll not leave any one do the oil cooler for me, it must be from an expert because bigger not always better, you might add bigger cooler but the oil pump will not support it and you will see drop on the oil pressure and then you will hurt your tranny because the low speed movment of the oil from the tranny to the cooler.
The TC alone will not do much, it will hurt your stock trany if you didn't do it all at the same time.
can some one tell me what is the stall on those upgraded TC ?
Old Apr 13, 2010 | 03:17 PM
  #50
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
in fact i do not know that guys ... the problem is ,, when we opened the gearbox in the work shop we did not find anything broken or damage , just burned oil ,, and i did alot of streat races just notice slippin between the 2nd and 3rd shift ,,
tuners told me if i upgrade the TC it will not slip again ....
Old Apr 13, 2010 | 05:05 PM
  #51
besiktas's Avatar
Whiteknight upgraded my tranny and I have the gt3071 kit from protomotive. we added more discs, kept the TC standart as it does not have anything wrong on it. the shiftment is very quick and hard now, almost like PDK. I did 100 - 200 km in 4.7 seconds with upgraded tranny. Before this upgrade the car was slipping a lot at 1.4 + bar of boost, I have pushed the limits to 1.6 bar, so far so good.
Old Apr 13, 2010 | 07:02 PM
  #52
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Awesome results
What was the boost with 4.7sec ran?
Old Apr 13, 2010 | 10:43 PM
  #53
milou's Avatar
For those he did this modd please provide somepics and information for us,
part numbers?
number of parts?
cost of parts?
photoes?
feedback
thx
Old Apr 14, 2010 | 12:27 AM
  #54
ysfg35's Avatar
part numbers?
number of parts?
cost of parts?
photoes?
feedback
thx
1+ yes please , you will help us alot ..
when i talked to the guy in the work shop , he told me that there are no place to add more discs ... so please tell us how you do it ??
thanks
yousef
Old Apr 14, 2010 | 02:16 AM
  #55
997John's Avatar
thanks
yousef
As WhiteKnight said you should send him K2 & K3 so he will modefied them for you.
Old Apr 14, 2010 | 02:19 AM
  #56
ysfg35's Avatar
its hard to send parts of my car , i do not love it staying in work shop for long time ...
Old Apr 14, 2010 | 02:21 AM
  #57
besiktas's Avatar
Originally Posted by Shotcaller
Awesome results
I did it in 1.5 bar with 91 pump / methanol. Will try with 104 octane today.
Old Apr 14, 2010 | 02:25 AM
  #58
997John's Avatar
Some time you should do it. You can contact WhiteKnight and see how long he need to do the jop for you.
Old Apr 14, 2010 | 04:09 AM
  #59
ysfg35's Avatar
i will tell him
thanks man
Old Apr 14, 2010 | 04:24 AM
  #60
997John's Avatar
That's nice WhiteKnight
If i'm using bigger turbos on my Tips porsche do i need to do more like vavle body etc.. ?
