New clutch required?
#76
Bogg
It is not the standard GT3 clutch disk.
1878000802/996 116 015 32 clutch disk for use with Single-Mass Flywheel only.
I guess the clutch material is different and it will hold my HP/TQ level.
#77
Having GT3RS Flywheel/clutch kit installed.
Bought the kit from Todd/Protomotive and he said this was the quietest LWFW option around.
GT3RS lwfw 964.102.239.31
GT3RS Clutch Disk(Sprung) 996 116 015 32
Stage3 PP 88 3082 999 764
release bearing, pilot bearing, ring gear, bolts etc.
Will let you know how I like it.
#78
Ronnie
It is a sachs motorsport clutch disk the number on it is 1878000802
which equates to 996 116 015 32 which is the GT3RS clutch disk.
The price from Todd/Protomotive was $2998.50, it is expensive but has all sachs motorsport parts.
#79
ok thanks got it! when are you plan on installing this kit?
#81
My clutch slips madly in 4th 5th and 6th WOT at about 4500+ RPM. The needle hits the rev limiter but the car does not accelerate. Also noticed shift points between gears immediately puts me in the 3400 RPM range now.
I only have an EVOMS tune and don't go WOT every time I've driven.
It really seems acceleration is not as fast any more. Also noticed some motor laziness as if the turbos are reluctant to spool. Like a lubrication or loose hose issue.
Car has 8K miles now. (?)
#82
You obviously need a new clutch set-up. With a slipping clutch your load measurement is going to be messed up which will decrease boost (clutch may be slipping before you even notice it). Install a new clutch and see if that solves the problem.
#83
Venkat, do you know how much power/tq this combo can handle? I was considering the AWE/Sachs stage II.5, but this also sounds like a contender.
#85
So who makes the EVOMs clutches stage 3 and 4 which are good for 7-800whp/tq iirc?
#86
The below is an excerpt from renntech forum, what do you guys think of installing lwfw, are there any concerns as mentioned below by porsche NA on 997 turbo.
I think (this is my opinion) if you use dual mass fw , then go with a unsprung disk, and if you go with a LWFW then go with the sprung clutch disk as the sprung clutch will take some of vibrations and single sided load on the crank, not sure but in theory it sounds right?: thats why the gt3 rs uses a sprung clutch with a lwfw?
from renntech
Concerns: Flywheel and pulley
Information: Replacing dual-mass flywheel with single-mass flywheel.
We have discovered that the dual-mass flywheel, which is installed as standard in the GT3 engine (vehicle type 997810/-811), is being replaced in the dealer organization with the single-mass flywheel from the GT3 RS engine (vehicle type 997850/-851).
Information
Due to an increasing number of reported faults, we expressly wish to point out that the installation of the single-mass flywheel (from the GT3 RS) in the GT3 engine is not approved by Porsche.
Since the 911 GT3 (997) engine application is designed for the dual-mass flywheel, conversion to the single-mass flywheel results in the following problems and consequences:
• The single-mass flywheel causes fluctuations and vibration in the lower rpm range, thereby reducing the smooth-running performance of the engine.
• The crankshaft is subjected to one-sided loading, causing stress peaks that can result in damage to the crankshaft.
• The one-sided loading of the crankshaft can cause the pulley to come loose, resulting in damage to the belt drive and engine.
• Any damage relating to conversion or damage that can be attributed to conversion is not covered under warranty.
Please advise your customers of this information accordingly.
©Porsche Cars North America, Inc.
from renntech
Information
#87
Spoke to Kevin at UMW during my research on LWFW/clutch kit.
His thoughts were identical to your excerpt from Renntech
His thoughts were LWFW should always go with sprung disk due to loads on crank/casing. Dual mass is fine to use solid disk(GT2)
Glad Todd kits has the sprung disk.
#88
With all do respect to Kevin and his vast experience with LWFWs, I do not believe that the TSB that Porsche published in 08 has anything to do with a sprung versus unsprung clutch setup.
That TSB was issued by Porsche to prevent owners from converting to a GT3RS flywheel setup. The kit that most dealers and tuners use already has a sprung clutch...and while this reduces the chatter at idle, does not necessarily eliminate the problem described on the GT3. Even after using an RS pulley, some still reported the bolt becoming loose.
The problem has nothing to do with the LWFW. Or the pulley. It has to do with properly installing the pulley with the correct torque on the pulley bolt, installed with Loctite or other static bolt compound. Ask around the 996GT3 community and see how many people have a LWFW conversion that are running strong. Then ask the ones that had an incident if this was a engine problem or a pulley problem. Nearly every combination of sprung and unsprung clutches have been used with LWFWs...both on the GT3 and Turbos. A sprung clutch does not prevent the problem. Proper installation does.
#89
On our forum alone, dozens of members here have LWFWs with unsprung clutches...both on the Turbo platform and on the GT3. A sprung clutch will not prevent the pulley bolt from loosening...improper installation causes this.
#90
I have had nearly every combination of sprung/unsprung/LWFW on my 3 previous 911s. An sprung clutch transmits less noise than an unsprung clutch, especially at WOT in a high gear (lugging the engine.) But it is not a necessity. Proper installation is the important part of the conversion. Proper torque to the pulley bolt and Locktite (or similar) will prevent the problem.
