Talk to me about headers.
Old Feb 28, 2010 | 08:01 AM
cannga's Avatar
To OP -- see the thread that bbywu quoted above. Header is a complex component and requires matching with the rest of your setup, including your ECU tune. Some argue a re-tune of the ECU after adding header. I most definitely would not just grab randomly a FVD header, or any header for that matter, and add to your setup. Go with what your Protomotive tuner tells you (I am sure he's not going to use FVD header.). And NO, don't grab a header based on "look"!!! (Or sound.)
The header should NOT be the first component in your power upgrade. The most typically recommended path is exhaust, ECU, intercooler, and maybe header later on down the upgrade path.
A header shifts the power band (see below) and may not always be beneficial, depending on your driving style, engine power, etc.
http://en.wikipedia.org/wiki/Manifold_(automotive_engineering)
Great care must be used when selecting the length and diameter of the primary tubes. Tubes that are too large will cause the exhaust gas to expand and slow down, decreasing the scavenging effect. Tubes that are too small will create backpressure against which the engine must work to expel the exhaust gas from the chamber, reducing power and leaving exhaust in the chamber to dilute the incoming intake charge. Since engines produce more exhaust gas at higher speeds, the header(s) are tuned to a particular engine speed range according to the intended application. Typically, wide primary tubes offer the best gains in power and torque at higher engine speeds, while narrow tubes offer the best gains at lower speeds.
Old Feb 28, 2010 | 09:19 AM
ukgt2's Avatar
ukgt2 is a splendid one to beholdukgt2 is a splendid one to beholdukgt2 is a splendid one to beholdukgt2 is a splendid one to beholdukgt2 is a splendid one to beholdukgt2 is a splendid one to beholdukgt2 is a splendid one to behold
Thanks Guys.
I honestly had no idea that it was that complex an issue.
I will speak to todd when he does my map to see what he recomends.
Thanks again.
Old Feb 28, 2010 | 04:28 PM
dg123's Avatar
dg123 has a spectacular aura aboutdg123 has a spectacular aura about
i would go with tubi's..i love the note..at high speeds
Old Feb 28, 2010 | 06:55 PM
997tt RS 2.7's Avatar
997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of
ditto:d
Old Mar 1, 2010 | 03:39 PM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
With the regards to "stages of power", and since we don't have a "stage 1" package, you will not find significant gains under 650hp - the break line on where our packages include headers.
We can do them in polished or ceramic coat:
These are good for well over 1100hp, as well.
Old Mar 1, 2010 | 04:25 PM
FLT6SPD's Avatar
FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !
It is all about the routing of the exhaust pulse through the manifold, think about it, equal length manifolds with allow the engine to be more efficient than a log style manifold.
C5tt
Oct 24, 2015 07:35 PM
505996tt
Oct 6, 2015 07:18 PM
