Message Failure
Old Mar 20, 2010 | 04:05 AM
Porsche Boy's Avatar
Porsche Boy is a jewel in the roughPorsche Boy is a jewel in the roughPorsche Boy is a jewel in the rough
Message Failure
Hi gentlemen,
My friend recently got a message on his car car stating :
- Failure of engine comp. blower
Any idea what this means?
Thanks in advance.
Old Mar 20, 2010 | 05:39 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
The fan on the engine lid is not functioning.
Old Mar 20, 2010 | 06:00 AM
Thanks bud. rep to you.
Old Mar 23, 2010 | 07:08 PM
Alnoaimi's Avatar
Alnoaimi is infamous around these parts
Originally Posted by Porsche Boy
Hi gentlemen,
Thanks in advance.
Check the sensor. I had the same problem and it was from the sensor of the fan. Replacing the sensor first can save u $200 (Fan price).
Old Mar 23, 2010 | 09:11 PM
FSU-997TT's Avatar
FSU-997TT is infamous around these parts
There is also a relay(s) that could have failed. My fan was replaced, same message came back....then the relay was replaced.
Old May 15, 2010 | 04:53 PM
HunterTurbo's Avatar
HunterTurbo is infamous around these parts
I just had this same message come on today. I need to do a 200 mile highway drive tomorrow. Any idea if it's safe to drive it with this warning on?
Old May 15, 2010 | 07:09 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
I wouldn't do it.
Old May 16, 2010 | 12:03 AM
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
You should be fine. I just had this problem and it took the dealer time to sort the fix out. Keep your eye on the gauges and you will see the oil and water temp stays the same. If you stop and its hot out just pop the rear bootlid so it let the hot air out of the engine compartment.
Old May 16, 2010 | 06:08 AM
Great, thanks guys. I'm going to make the drive, just keeping any eye on things...
Old Jun 1, 2013 | 01:00 PM
illusionist's Avatar
illusionist is infamous around these parts
Hello Folks, I have the same error. Can you please help me locate the blower relay and fuse?
SlinginHoss
11
Oct 8, 2025 05:16 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
