Reducing throttle response....
Old Mar 27, 2010 | 07:42 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Believe it or not, I'd like to reduce my throttle response, especially when sport mode is engaged.
I find I drive more on regular mode because I like the normal mode throttle response better. I find it easy to make smooth take offs and shifts.
I also wanted an evo stage II program but when I found out the throttle gets even more sensitive, I wrote that option off.
I have asked this question before but not for a while. So I wonder, is there a program or part to reduce throttle response? My ideal situation would be normal throttle response in sport mode.
Old Mar 27, 2010 | 10:19 AM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
David - when you flash your car, you can maybe have them tweak your throttle response. EVOMS may be able to help with this. Talk to Todd at EVOMS.
Old Mar 27, 2010 | 11:59 AM
Periokid's Avatar
Neil, That is interesting. I'll have to inquire on that one. Thanks.
Old Mar 27, 2010 | 12:29 PM
lardog's Avatar
lardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to all
reduce throttle response? get a C4S JK
Call Scott from Softronic. they can do that for you.
Old Mar 27, 2010 | 11:48 PM
TT Surgeon's Avatar
FVD can customize a flash to your exact parameters, drive mine sometime, you'll be on the phone the next day.
Old Mar 30, 2010 | 07:26 PM
Softronic's Avatar
Veteran: Marine Corps
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
Softronic can increase or reduce your response at any percentage you could ask for. Would you like 110 % or a reduction of 10% from stock? Perhaps 99.91%? Whatever it may be Softronic has and uses the latest technologies from the company that made the original software for your car. Rev limiter set for 7200,7205 or any other number..... etc.
Best Regards,
Softronic
Old Mar 30, 2010 | 08:53 PM
Periokid's Avatar
Best Regards,
Softronic
That is nice to hear. So let me ask you...can sport mode stock throttle response be made to be the same as normal mode throttle response? That is, no difference between the two setting in regards to throttle settings.
Old Mar 31, 2010 | 09:25 AM
MorePSiTehBett4's Avatar
MorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really nice
I'm sure if he can do all that other stuff that would be no problem ^^^
Old Mar 31, 2010 | 03:16 PM
Softronic's Avatar
Hello,
Yes it can be done yet never asked for. Simply the map switch for the increase can be turned off in the DME.
Best,
Scott Slauson
Old Mar 31, 2010 | 03:21 PM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
I have Softronic tune and it is amazing.
Pulls like a freight train in both the standard(I5 psi) and sport mode (18+ psi)
I did not request reduced throttle response in sport mode.
I like the throttle response in sport mode as it came with the tune, very aggressive.
Old Mar 31, 2010 | 07:06 PM
gmoney's Avatar
if you slow the rate down it may be harder with sport chrono on to hit the overboost function. just a thought.
Old Apr 5, 2010 | 03:59 PM
Periokid's Avatar
Interesting point. I wonder if the software upgrades would take care of that.
Texas1
Sep 20, 2015 09:12 AM
Bmanny
Sep 16, 2015 08:29 AM
albert@velosdesignwerks
American Muscle Vendor Classifieds
Sep 9, 2015 04:21 PM
Other British Cars
Sep 9, 2015 04:18 PM
Sep 9, 2015 04:17 PM
