Removing front lip spoiler
Old May 2, 2010 | 02:18 AM
dksu's Avatar
dksu has a spectacular aura aboutdksu has a spectacular aura about
I just got my painted front lip spoiler. How do i remove the stock lip spoiler? Do i need any tools? Does the car have to be jacked up? thanks
Old May 2, 2010 | 03:43 AM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
i think u only need a scrow driver " torx " as i remember !
Old May 2, 2010 | 07:22 AM
handdoc's Avatar
handdoc is infamous around these parts
just look underneath, i believe you need a torx bit and have to remove one of the plastic covers to get to it
Old May 2, 2010 | 10:29 AM
HUMMM 3's Avatar
HUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud of
A short length Torx screw driver to remove two screws (one at each end of the lip). There are no covers to deal with. After removing the screws just pull on the lip starting at one end and it will come right off. I tried pulling from the center and THAT won't work. Look at your new lip and you'll see the connecting tabs that press into holes on the bottom of the bumper. Once you start removing the old lip it should almost come off like a zipper. No drama!
Old May 3, 2010 | 01:18 AM
997TTurbo's Avatar
997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold
T-30 Torx bit is the correct size.
Old May 3, 2010 | 01:26 AM
dksu's Avatar
Thank you guys
Old May 3, 2010 | 01:43 AM
speed21's Avatar
Never done the job myself but my panel/paint guy who fittted my techart lip said the bar was basically a full stripdown....headlights out, bar off, plastic grille inserts both off etc etc... to get the clips on and off. It may be way simpler for the stock lip though. Good luck as they both attach the same way on the bar .
Old May 3, 2010 | 10:56 PM
HUMMM 3's Avatar
Wow! Headlights out, grille inserts off. It's a wonder your panel/paint guy didn't charge you for headlight fluid.
Stock is very simple. In fact if I know I'll be driving over rough roads or where I'll probably scrape I'll take the painted lip off and put the old stock one back on.
Old May 3, 2010 | 11:14 PM
speed21's Avatar
Oh well so much for BS. I seem to always get it in spades when its pay up time. It seems the bigger the bill the bigger the BS story. Anyways nice to know its no big deal to fit one. cheers..
Lowtush
Jan 25, 2022 10:48 AM
Nissan GTR
Aug 19, 2015 02:11 PM
