FOG Lights- indicator help
Old Aug 5, 2010 | 08:01 PM
tclayj's Avatar
tclayj is infamous around these parts
I noticed tonight with my lights on that when I turn on my fog lights the indicator on the switch goes from a white light to no light. But with the rear it changes from white to yellow. Is might be my imagination but I swear that it use to light up green. Has the green bulb malfunctioned or am I confused with my Rover ?
Old Aug 5, 2010 | 08:07 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
sounds like your fog light indicator went out. Should be green when on.
Old Aug 6, 2010 | 06:50 AM
tclayj's Avatar
Would I need to replace the switch and if so what is the part #
Old Aug 6, 2010 | 11:47 AM
NeilM's Avatar
Contact your dealer. Need to find out exactly which part is bad.
Old Aug 6, 2010 | 02:53 PM
bbywu's Avatar
The light switch is sold as an entire unit. If the LEDs are working to light up the indicators for all but the fog lights, chances are the LED for the fog light indicator is out. It is not available as a separate unit. The part number for the entire headlight switch component is 997 613 535 01.
Old Aug 6, 2010 | 02:55 PM
bbywu's Avatar
Instructions for replacing the headlight switch surround (and hence the headlight switch itself) is here:
http://www.youtube.com/watch?v=4166V...layer_embedded
Thanks should go to Lane and MACarbon who created the instructions.
bob
Old Aug 6, 2010 | 04:20 PM
tclayj's Avatar
Thank you all for the most excellent advice and help.
adnanm3
Oct 25, 2016 08:38 AM
randalldahme
Feb 19, 2016 03:56 PM
Glasgo
Nov 30, 2015 02:37 PM
ECS Tuning - BMW
Sep 10, 2015 02:51 PM
