Check your nuts (and bolts!) regularly
Old Sep 3, 2010 | 02:42 PM
The Bogg's Avatar
Not those ones.
I was washing my car the other day and noticed that the left tip on my AWE exhaust was sticking out farther than the right one. I thought just the tip had come loose like it had when I first had the exhaust put on but upon closer examination I discovered that the tailpipe section after the muffler can was loose enough to allow a bit of swivelling. I don't know if the tailpipe would have eventually fallen off but I do remember that picture of the burnt rear fascia from the tip that fell off another 6speeders car. Don't need that wallet draining failure thank you.
I tried tightening the clamps but it didn't hold b/c I wasn't able to properly push the tailpipe piece further into the muffler "lip" without elevating the car. I'm taking it in next week to have all connections checked. This is scary, as it was originally tight. I understand that with heat/cold cycling a joint can loosen but I didn't really expect this. Has it happened to anyone else?
Old Sep 3, 2010 | 05:45 PM
bbywu's Avatar
I think someone reported losing a stock exhaust tip a year or two ago. Went flying off on the freeway.
I would have thought repeated heat expansion would have made for a more solid connection.
Old Sep 3, 2010 | 06:14 PM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
ones you do that it is good to check entire exhaust ,specially the headers.
Old Sep 3, 2010 | 06:39 PM
Arone997tt's Avatar
Arone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud of
tack welded mine on...would never trust a set screw
Old Sep 4, 2010 | 04:39 PM
gmoney's Avatar
stock exhaust tip can strip after a few remove and replacements, the are frankly cheap flimsy parts when you compare them to the 997.2 TT tips. Dont overtighten them, snug is fine as when it heats up they expand.
Old Sep 4, 2010 | 08:50 PM
The Bogg's Avatar
Mine is the AWE exhaust and tips. The clamps look really heavy duty. I would also have thought the heat cycles would have helped keep them tight but it doesn't look that way unfortunately.
Old Sep 7, 2010 | 08:39 PM
The Bogg's Avatar
Had everything checked and tightened today. Shop says that if they come loose again it may be worth tack welding the bolt so it doesn't back off. Hopefully doesn't come to that...
Old Sep 7, 2010 | 11:05 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
I'd use a lock washer or even a lock nut on it.
Old Sep 8, 2010 | 04:12 AM
handdoc's Avatar
handdoc is infamous around these parts
TT Surgeon has written numerous times that the modular exhausts that are clamped together tend to loosen...he has recommended frequent checks and retightening due to problems like this...its good that you are having the system checked
Old Sep 8, 2010 | 07:42 AM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Will using red loctite help?
Old Sep 8, 2010 | 10:01 AM
TO08TURBO's Avatar
TO08TURBO is infamous around these partsTO08TURBO is infamous around these parts
Red loctite can withstand heat, so it should help.
It can also be a pain in the you know what when it comes time to remove it.
Old Sep 8, 2010 | 07:18 PM
The Bogg's Avatar
I must've missed those posts. What brands of exhaust are not modular, i.e. are full weld up to the tips? Just curious, I'm not about to replace the exhaust. At least now I know to check it regularly and get the tack weld if necessary.
Old Sep 9, 2010 | 03:43 AM
handdoc's Avatar
Tubi is one piece except for tips
007 Vantage
Sep 4, 2015 06:55 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Lucid Moment
Aug 20, 2015 02:22 PM
cab83_750
Aug 19, 2015 12:37 PM
