Do Upgraded Turbos Require Catless Race Exhausts?
Here is what we got on first modded vtg's car from Milltek exhaust w/200 HJS cells lto Prototech/Protomotive catless X-Pipe exhaust system
100-200kmh we shaved 0.5-1sec...mid 6's
200-300kmh we shaved 4-5sec.....13's-15s's
We gut Ruf 200cell exhaust also we got impressive results also
We tested Protomotive catless X-Pipe exhaust system on stock , modded VTG's and even cars w/GT kit...We got SICK performance and sound!
Back pressure on Stock 997TT: 0.44bar/6.38psi
Back pressure on Europipe EP1: 0.18bar/2.6psi
I am surprised that other exhaust vendors don't want to share this data. I guess not everyone wants to drop their pants in public.
Thanks for that. Would you happen to know Milltek's back pressure?
Why u dont check 60-130/100-200kmh and 125-186/200-300kmh and let u know so we could compare it with modded vtg's w/catless exhaust??
The car was tip ran 0-300kmh in 22-23sec before about couple of years
His car has is 2007 Porsche 911 Turbo 6-sp
Protomotive ECU, Turbos
Headers, Exhaust
Stock tires, pump gas
http://www.youtube.com/watch?v=RNS71l9zrrM
I answered the power and performance side of things.
The sound quality of the straight pipes is deafening.
Inside the car, it is way too loud and if you take a trip longer than 10 to 15 minutes, you are guaranteed to arrive to your destination plus a headache.
I have two friend running the Protomotive catless x-design exhaust. Sound is OK, performance is excellent.
I preferred going a different route. I bought the new Europipe 997.2TT exhaust. 100 cell racing cats with a much bigger diameter than the stock cats which has 600 cells.
If and when I upgrade the turbos, I can always order cat delete piped from EP for even lower back pressure.
That would be my recommendation. I think it will give you the ideal compromise of sound to performance.
Karim, you sure about that? The cats are welded to the mufflers (at least mine are) and EP has never offered a catless system before because I believe it was against the law to do so.
A little cutting and welding may be required, but it should not be too difficult if EP do the tubes with all the right bends and provide clear instructions on where to cut, etc...
I will check with Stef if it's possible/recommended.
Larger turbos will always benefit from running a catless system.. Even 200 cell cats create back pressure and higher EGT's.. You will make more power catless at the same boost level and you can run even a little more boost catless as well due to the lower EGTS.. I had a GMG catless system and there wasnt much drone on mine.. Im not real picky though so not sure i paid so much attention.. i drove it daily with no issues tho..
Mike
Mike
Mike
ep2 loud
In the next few weeks I will be putting my car on the dyno it has 30/76 turbos with all supporting mods, I really don't want to lose the ep2 loud.
this will be a good test for the exhaust I am looking for about 775-800 rwhp with the exhaust and cats. If it is too restrictive 725-750 I will get a new exhaust. I hope it works.
