Finaly i finished dyno my car rwd -Tip GT3076
Old Sep 14, 2010 | 04:57 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Talking Finaly i finished dyno my car rwd -Tip GT3076
After alot of search i found that dyno 997tt rwd is not hard as i Expected !!
Its very easy and simple ..
1- first thing is you need to take out the drive shaft ( easy job )
here is the drive shaft :
2- when i started the car it moved normally , i did not take out any fuse and i checked the break if its stucked on the discs but everything was fine !
3- after that i went to the dyno to see how much HP i will get
but .. before putting the weels on the dyno roll .. i opened the fuses box https://www.6speedonline.com/forums/...7-1-turbo.html
i taked out the fuse 8 and 10 in C row,after that i started the engine but it did not move .. alot of warning signs appeared in the dash
so i repluged the fuse (8) in his place again
so it back moving normaly just ABS/PCM warning appeared on the dash but it moved
Now the dyno ..
the weather was hot 39c , Unfortunately i did not use the CO2 IC spray ( the bottle was empty )
and i set the boost controller to 1.3 bar with meth !!! i just want to know the power in pump gas in mid boost
the car reached 660whp
here is pic of the dyno
what do you think ???
Old Sep 14, 2010 | 05:38 PM
skeeter's Avatar
skeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond repute
Awesome! Thats some really good power as well....Dynojet's tend to read lower than other dynos...Thanks for the diy on rear wheel dynoing also!
Old Sep 14, 2010 | 05:40 PM
ysfg35's Avatar
thanks alot ,, when i install my upgraded parts i will try again with 1.6bar
Old Sep 14, 2010 | 06:23 PM
MishaDesigns's Avatar
Incredible pull!
Old Sep 14, 2010 | 06:38 PM
Divexxtreme's Avatar
Nice! That's around 650 whp SAE.
Old Sep 14, 2010 | 07:26 PM
FLT6SPD's Avatar
FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !
What are the trq#'s? Can you post another with torque curve and rpm axis?
Old Sep 15, 2010 | 12:51 AM
ysfg35's Avatar
Originally Posted by 996wings
Incredible pull!
thanks for your sweet words
Old Sep 15, 2010 | 12:54 AM
ysfg35's Avatar
thanks , to be honset i did the dyno to compare the results now and later after installing the new injectors and upgrad the gearbox
Old Sep 15, 2010 | 12:58 AM
ysfg35's Avatar
am sorry the guy in the dyno did not do the trq#s
Old Sep 15, 2010 | 03:18 AM
Arone997tt's Avatar
Arone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud of
any internals done to motor?
Old Sep 15, 2010 | 03:19 AM
ysfg35's Avatar
stock internals bro
Old Sep 15, 2010 | 03:21 AM
Arone997tt's Avatar
thanks..how long have been running this set-up?
Old Sep 15, 2010 | 03:26 AM
ysfg35's Avatar
8 months ..
you can see the installtion step by step here https://www.6speedonline.com/forums/...7tt-story.html
Old Sep 15, 2010 | 03:40 AM
Arone997tt's Avatar
thanks bro
Old Sep 15, 2010 | 07:50 AM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
I can't imagine being RWD with that kind of power (not to speak about 1k rwhp cars....)....My car loses traction in 3rd gear with only a tune and exhaust!!
