Abs, ptm, psm, and pasm failure !!
Subscribe
Sep 17, 2010 | 11:53 AM
Hello,
After I changed the tie rod end I had ABS, PTM AND PSM Failure lights and the car is completely crazy the performance is reduced and as soon as hit the gas it might spin if it was a full throttle, anyone have an idea about this issue? we checked all the sensors and tested all of them and r working fine !
1 day later the PASM was working fine * sport absorbers * as soon as I pressed the sport absorbers to check if it is working or not, it was fine, but as soon as I turned it off I started to have one more failure PASM failure.
The car is 997 Turbo 2008
Any idea guys?
Reply
Sep 17, 2010 | 12:10 PM
Check your connections in the area you where working, if that was the only place where work was done. Clear the fualts and try again.
Reply
Sep 17, 2010 | 12:14 PM
We checked the wires and unplug everything and plugged them back but still same error.
we had unknown fault, and steering angle sensor, and speed sensor these faults were cleared but after we restart the car, the faults come back.
Reply
Sep 17, 2010 | 05:45 PM
Reply
Subscribe
