Start up smoke only on driver side pipe??
Old Sep 30, 2010 | 02:24 AM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Hey Guys,
I have noticed that whenever my car get a puff of smoke at start up; the smoke always come out of the driver side pipe. I do idle the car around 3 minutes before I shut if off and leave the engine lid open while in the garage and the car smokes very very rarely.
I have watched a few youtube videos on exhausts. All those cars that smoked at start up only had smoke coming out of driver side pipe or more on driver side and a little on passenger side. why?
I have also noticed that my drive side exhaust tip has a tiny little bit more soot than the passenger side. Can you guys check on yours and report back?
Thanks alot!
Old Sep 30, 2010 | 05:56 AM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Mine does this too. But I know why, two valve guides on the drivers side are leaking a bit more than the others, so a bit more oil go down into the header while the car is still.
P-tech said it's no problem as "all of them" leak a bit through the valve guides.
Old Sep 30, 2010 | 02:51 PM
Abby997TT's Avatar
Thanks alot for the info.
anyone else have noticed the same thing?
Old Sep 30, 2010 | 02:57 PM
raclaims's Avatar
raclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to behold
Mine smokes too...and gives off a noxious smell that makes me gagg and cough...good stuff.
Sounds great though...despite the poison gas.
Old Sep 30, 2010 | 10:31 PM
Abby997TT's Avatar
It does smell abit, and it's so thick that my neighbor thought I blew up the motor again
Old Sep 30, 2010 | 10:53 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
AGAIN?!?
Did you seriously blow your motor?
Old Oct 1, 2010 | 12:09 AM
Abby997TT's Avatar
Not the turbo . I have blew motors in my previous cars before.
Old Oct 1, 2010 | 06:32 AM
ruf_turbo's Avatar
Glad to hear that , but you caused me nightmares last night.
Old Oct 5, 2010 | 11:21 PM
Abby997TT's Avatar
here is a video i saw on youtube. the car seems stock and only blow smoke on the drive side pipe.
http://www.youtube.com/watch?v=ZI6SwSe2a-Y
Old Oct 5, 2010 | 11:29 PM
ruf_turbo's Avatar
It looks like both sides to me but more on driver side.
Old Oct 6, 2010 | 09:59 AM
cgng30's Avatar
cgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to behold
I switched to mobil1 5w-50, since then I haven't. Seen any smoke, will keep posted, I am assuming all you guys seeing smoke are using 0w-40 ?
Old Oct 6, 2010 | 03:17 PM
emadelta86's Avatar
No I'm using 5w-50. But I see no smoke if: -I let the engine go on full operating temp -I let it idle a couple of minutes before shutting it off .
Many many times the smoke can just be water....yes...coming from bad gas... If the gas station is not a "busy" one, you can fill the car with gas that has a high percentage of water in it, and when the exhaust is cold on sturtup the water condenses and then evaporates when it gets warm enough, causing "smoke".
If you see little drops coming from the tips, that's water, not oil. But you can tell easily from the smell if it's oil though.
Old Oct 6, 2010 | 03:33 PM
kenromero's Avatar
kenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond repute
My 2007 TT does this also. I also use a quart of oil every 1000 - 1200 miles. What has been your oil usage?
Old Oct 6, 2010 | 03:58 PM
ruf_turbo's Avatar
+1, especially letting it idle a minute or so before shutdown.
Old Oct 6, 2010 | 06:02 PM
gt34me's Avatar
gt34me is infamous around these parts
Ol' Smokey Syndrome, especially with track use....
